Stupid mistake I made..
Old Oct 5, 2008 | 06:55 PM
Customcab's Avatar
Customcab
Yesterday; I was trying to reinstall my 302 / c-6 combo into my 78 model. I must of had the torque convertor in a bind, after I had the trans matted to the engine, I was tighing down the torque nut to the fly wheel. I couldn't turn the torque convertor; so I was removing the trans bell bolt from the housing ( to reangle the trans) and must of had the angle between the two parts in a bind and as I was removing the final bolt it snap a portion of the bell housing shell.
I learn lesson the hard way...........................
Mitch
Old Oct 5, 2008 | 07:02 PM
73f100shortbed's Avatar
73f100shortbed
That sucks. Any way to fix it easily? Or bad enough you need trans.?
Old Oct 5, 2008 | 07:04 PM
Dr. Dirt's Avatar
Dr. Dirt
no.
Old Oct 5, 2008 | 07:07 PM
Rockstone's Avatar
Rockstone
No JB Weld fix?
Old Oct 5, 2008 | 07:22 PM
Customcab's Avatar
Customcab
Been told its possible to weld, my departments Chief Mechanic has a aluimimum welder; unfortunatlty he's alittle under the weather, maybe he can weld it tuesday. It snap at the bolt hold which holds the fill tube. I have another trans; but never torn one down. As you can tell by my initial post, I'm just a shade tree mechanic; with alot of leaves missing.
Mitch
Old Oct 5, 2008 | 07:27 PM
Dustin1690's Avatar
Dustin1690
That sucks...
Old Oct 5, 2008 | 07:34 PM
Customcab's Avatar
Customcab
And then some!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mitch
Old Oct 5, 2008 | 08:56 PM
fastfarmer's Avatar
fastfarmer
That sucks, but don't get too worried about it. From 62 till 65 1/2 the 221-289 Ford engines only used 5 bell housing bolts anyway. Back in the 70s and 80s I installed several Buick-Olds-Pontiac trannys behind chebbys using adaptor plates that attached the tranny with 4 bolts.
Just to be clear, was your problem that the torque convertor was not fully seated in the front pump in the tranny?
Old Oct 5, 2008 | 09:22 PM
SPINPOSI's Avatar
SPINPOSI
Sick feeling, right there....
Let us know if you repaired or replaced....
-J
Old Oct 22, 2008 | 09:06 AM
countryboy1982's Avatar
countryboy1982
forest says "It happens".
Old Oct 22, 2008 | 03:26 PM
davethecow's Avatar
davethecow
only true way to learn anything is thru experience
Old Oct 22, 2008 | 04:09 PM
Pickupmanx2's Avatar
Pickupmanx2
Been there done that one myself also,,,, I feel your pain!
Old Oct 22, 2008 | 04:47 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
Unless you have a ton of horsepower I wouldnt worry too much about it. I busted a bolt hole off a tranny once when I was in high school. I put it all together without one bolt and it held up fine. Kinda like lugnuts...you can live without one.lol
Old Oct 22, 2008 | 08:48 PM
Customcab's Avatar
Customcab
I'm with ya (Fordtruckskickgmon) the level of stress on my truck isn't to demanding; should do fine. I did have it welded and currently back together. Tomorrow we'll hopefully get the front clip back on after touching up some basic automatic parts like p/s a/c ingition parts back attached to the inner fenders.
Mitch
Old Oct 22, 2008 | 10:51 PM
geno001's Avatar
geno001
Hey Customcab, been there, done that, no big deal. Get someone who is handy with a tig welder, make sure he preps it right, weld it up. Never have a problem with it. My stupid mistake was with a 460/c6.......note to self, never use the bolts to draw the tranny and engine together.
