Four wheel drive won't engage
It may not be either motor or solinoid. There should be a wire that controls the 4x4 engagement, I haven't eyeballed one but I have on a che.. I can't write that but you know what I mean. It should run down to the front axle itself. I have seen them get ripped off that other brand of truck, but not the fords. So look around for a loose wire, that may be your problem. Other than that, yea it might be a solinoid, but I couldn't tell you where it is. And yes you would be better off with manuals. They always work, unless broken. Hope that helps.
RubberDuck
RubberDuck
If your front driveshaft is turning when you engage 4WD then it definitely sounds like your hubs are bad. The easiest way I know of to check it is to put the truck in 4WD then crawl underneath and see if the front shaft will turn. If the shaft won't turn then your hubs are most likely bad. Manual locking hubs are a straight-forward replacement and a LOT cheaper than replacing the auto-locking bombs. Hope this helped.
