oil leaks
Old Oct 4, 2008 | 04:03 PM
tnardo's Avatar
tnardo
oil leaks
just got underneath to tighten up the drain plug and check tranny fluid, i noticed there seem to be more oil leaking than before, my buddy is a ford tech and mentioned something about some o rings, i believe on the hpop, but that does not seem to be the cause the valley doesnt seem to be to awful wet, valve covers look dry... most of the oil i can see on the side of the block towards the rear right above the starter and it comes down and loooks like a rear main leak, i'll get some pictures up tonight. are there any specific things i should be looking at .
Old Oct 4, 2008 | 04:06 PM
ron's power stroke's Avatar
ron's power stroke
the weap hole for the valley is on that side..give your turbo and pedistal a good looksy..if it was high psi oil you would have a big mess at the front of the valley....at the turbo it would go right out the weap hole..
Old Oct 4, 2008 | 04:08 PM
GEugeneS's Avatar
GEugeneS
My copper drain plug washer leaked every time for a year. Then I went to plastic and it's been dry as a bone for almost a year. Oil can blow around from the plug to other parts of the drive train. Wipe the plug dry and see what happens.
Old Oct 4, 2008 | 04:19 PM
tnardo's Avatar
tnardo
the plug was leaking but thats really not the issue.
so should i expect a problem with the turbo or just lines
pedistal???
Old Oct 4, 2008 | 04:22 PM
ron's power stroke
pedistal???
4 little orings..2 block to pedistal at the very back of the block 2 pedistal to turbo about center...need to shine a light deep under the pedistal and see if there is wet oil down there... be right back for a part ## for ya..
Old Oct 4, 2008 | 04:24 PM
tnardo's Avatar
tnardo
so i would guess oil is delivered to the turbo through this pedistal
Old Oct 4, 2008 | 04:26 PM
ron's power stroke
it takes 2 of each
<TABLE id=DataGrid1 cellSpacing=0 cellPadding=3 rules=all border=1><TBODY><TR bgColor=#f2f2f2><TD>Turbo Pedestal (Large)</TD><TD>Viton</TD><TD>0.139</TD><TD>0.796"</TD><TD>1.074"</TD><TD>McMaster-Carr</TD><TD>#9464K32 </TD><TD>25@$7.18</TD><TD>-211</TD><TD>F4TZ-6N653-B</TD></TR><TR bgColor=#e5e5e5><TD>Turbo Pedestal (Small)</TD><TD>Viton</TD><TD>0.139"</TD><TD>0.421"</TD><TD>0.699"</TD><TD>McMaster-Carr</TD><TD>9464K544</TD><TD>25@$6.27</TD><TD>-205</TD><TD>F4TZ-6N653-A</TD></TR></TBODY></TABLE>
or ford dealer for about 17 bucks have them...
Old Oct 4, 2008 | 04:27 PM
ron's power stroke
correct..from block though pedistal into turbo for the bearing at the turbo wheel then back out the same way though the other hole
Old Oct 4, 2008 | 04:29 PM
tnardo's Avatar
tnardo
sound like the turbo is gunna pretty much come off for this, can you tell me what the deal is with this "wicked wheel"
Old Oct 4, 2008 | 04:34 PM
ron's power stroke
The Wicked Wheel<SUP>®</SUP> will:
  • Reduce or Eliminate Turbo Flutter/Surge in your 1994-2003 7.3L Ford Powerstroke.
  • Lower Exhaust Temperatures - NOT increase them
  • Increase Low-End Throttle Response - you may "feel" like your truck has more HP, but it DOES NOT
  • For use in 1994- 2003 7.3L Ford Powerstrokes
  • Is NOT intended as a horsepower mod.
The Wicked Wheel<SUP>®</SUP> will NOT:
  • Increase your performance
  • Increase your truck's horsepower
  • Increase or decrease boost
  • Increase or decrease fuel economy
and you get a really cool whistle
keep in mind..any performance wheel you see on any other site is a wicked wheel..in all fairness..its the early 99 stock wheel..they all just give it a differnt name
and yes..the turbo will need to come off to do orings...but give it a good look..and look at the EBPV arm on the pedistal to..see if oil drips from it..them leak some times too...
Old Oct 4, 2008 | 04:38 PM
tnardo's Avatar
tnardo
thank you......................
ron's power stroke
here is a how to on removing the turbo and putting in the WW..Bob at diesel site gives you one free set of oring when you buy the WW from him..just ask for a second set..
99-03 Turbo Removal & Wicked Wheel Installation .: Articles
