4" Factory Cat Mod
Old Oct 4, 2008 | 03:37 PM
FTX's Avatar
FTX
4" Factory Cat Mod
Hi Guys,
I recently installed a Magnaflow 4" Turbo Back and wanted to keep the factory cat for various reasons (no dealer hassle, being a little green, etc).
The cat adapters that came with the Magnaflow system were 4" adapters necked down to 3.5 (3.25?) fittings for the factory cat. This made no sense to me, why have a 4" system with a 3.5/3.25 bottleneck. Since the Magnaflow also came with a true 4" cat bypass I decided to use that and weld in the factory cat. The factory cat has flared ends going in and out of the cat section so I measured and cut right where the 4" Magnaflow pipe would slip inside the factory cat on the entry. I used the included Magnaflow 9" section with 2 flared ends on the outlet of the cat so I would have smooth airflow. This also eliminated one more connection point and one less clamp.
Turned out pretty well, just please don't give me a hard time about my welds, I am used to TIG welding aluminum and rarely do stainless :-)
Old Oct 4, 2008 | 03:49 PM
dcaddi2's Avatar
dcaddi2
I really do think that you did a beautiful job on the cat, and I like that you didn't "let them force" you to reduce your exhaust flow. Big thumbs up!!
Old Oct 4, 2008 | 05:14 PM
adambomb's Avatar
adambomb
looks good. how does it sound? notice any difference in EGT's?
Old Oct 4, 2008 | 05:30 PM
cparks's Avatar
cparks
Cat
That looks very nice. Great job!!!
Old Oct 4, 2008 | 06:20 PM
slowmans's Avatar
slowmans
nice job!
Old Oct 4, 2008 | 06:51 PM
FTX's Avatar
FTX
Can't tell any difference in sound yet. EGTs seem the same so far, but I haven't done any towing yet. Since I have a 4" downpipe and the cat is so far back I doubt I will see much diff in EGTs. There is no percievable difference in power, which I expected as all of my dyno testing with exhaust systems of various kinds I rarely see that much difference with or without cats....especailly one as big as the one on our trucks.
The only real difference I have noticed is there seems to be 0 smoke coming out of the exhaust when idling, without the cat I seemed to notice a slight amount of haze coming out of the exhaust at idle from time to time.
Thanks to everyone for your comments! Just wanted to pass along a simple idea in case others want or need to keep their cats and not lose any or much airflow with an aftermarket exhaust system.
Have a great weekend,
Old Oct 4, 2008 | 08:02 PM
SFeintuch's Avatar
SFeintuch
Very Nice, Great Idea.
Old Oct 5, 2008 | 02:40 PM
dc3655's Avatar
dc3655
Nice job on the fabrication! I'm hoping to have the same thing done to mine since the Magnaflow doesn't really come with a cat-retention pipe.
With the cat installed, does it sound the same as stock? I have no cat right now and it's absurdly loud with a weird "hiss" coming out the tailpipe. I'm just hoping that by welding the cat back in will quiet it back down to near-stock sound.
Old Oct 5, 2008 | 04:28 PM
King of the Road 04's Avatar
King of the Road 04
That weird hiss is more than likely the turbo.....and yes, putting the cat back on should quiet it down somewhat.....
Do you have a muffler installed? If not that will be needed if you want the truck be be close to near stock sound as you said.
Old Oct 5, 2008 | 10:31 PM
dc3655's Avatar
dc3655
I took my truck to an exhaust professional and he's going to weld in a Dodge Cummins Cat back into the system since it already has a 4" inlet and outlet. That combined with getting the downpipe off the firewall should help quiet it down somewhat. If not, I'm not opposed to slapping the stock exhaust back in....I've gotta keep the lady happy!
Oh yeah, I did have the Magnaflow muffler on, but no cat.
Old Oct 5, 2008 | 11:03 PM
DJR96's Avatar
DJR96
Wink
Good work Dave! And your welds are just fine too.
Good to see this done because I'm planning to do something similar.
Old Oct 7, 2008 | 06:08 PM
dc3655's Avatar
dc3655
Dave,
I liked your set-up so much that I almost copied it on my Magnaflow system. But instead of the small Ford Cat, I went with a Dodge Cummins cat since it already has a 4" inlet/outlet and it's a lot larger in size. I love the sound of my system now....it really does just sound like a stock system except that it gets on it faster!
Old Oct 7, 2008 | 06:19 PM
FTX's Avatar
FTX
Dc,
Glad that worked out for you!! Good idea on finding a larger factory cat. In my area it is Ford country, not too many of those Dodge thingys running around to snag a cat off of :-)
Old Oct 8, 2008 | 02:13 PM
dc3655's Avatar
dc3655
Dave,
The Dodge Cat came from the exhaust man himself since he cut it out of his brand new Cummins and it was just sitting on a back shelf in his shop. It's amazing the size difference in the cat on the Cummins, of course, the Cummins also comes with a 4" factory exhaust.
As a side note, there won't be so many Cummins or Duramaxes driving around here anymore as the Chevy Dealership and the Dodge dealership both went under in the last 2 weeks. It's sad to see the economy, but at least Ford has the edge here now!
FTX
Feb 18, 2024 12:02 PM
FTX
Mar 11, 2009 03:46 PM
FTX
Feb 15, 2009 07:13 AM
FTX
Sep 16, 2008 09:37 PM
FTX
Aug 31, 2008 12:40 AM
