400 Thermostat
Old Oct 3, 2008 | 10:35 PM
79FordBlake's Avatar
79FordBlake
400 Thermostat
What t-stat should be in a 79 400? I have a 190 in my 302 wondering if it is good for the 400 also? The one in my 400 right now is stuck open and it takes forever for it to get warm enough to have heat.
Old Oct 3, 2008 | 11:18 PM
mark a.'s Avatar
mark a.
I don't see how a t-stat could stuck open.
Old Oct 4, 2008 | 03:54 AM
fmc400's Avatar
fmc400
MSEE
It does happen. Try to stick between 190 and 195. The cooler an engine runs, the harder it is on your bearings. 190-195 is the ideal operating range. I've heard of thermostats as low as 165 which I do not recommend at all.
Old Oct 4, 2008 | 05:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
DOAZ8575A .. Thermostat-192 degrees (Motorcraft RT139) / Fits: 1970/82 351C/351M/400.
Old Oct 4, 2008 | 11:48 AM
grclark351's Avatar
grclark351
the Tstat for the 351M/400 and the 302 are different, they are not interchangeable at all.
Old Oct 5, 2008 | 09:00 PM
unrulee's Avatar
unrulee
Robert Shaw 33-192, fixed my issues. The usual over the counter parts store issue t-stats are not made to work in the 335 series Fords.
Old Oct 6, 2008 | 09:42 AM
beartracks's Avatar
beartracks
Robert shaw type all the way. They flow more are better built (different style) and if they do fail they will probably fail open instead of closed. I never seen one fail. I like 192 winter and 185 summer.
