Another problem
Old Oct 3, 2008 | 09:36 PM
akghound's Avatar
akghound
Another problem
This code just showed up -- P1272 High to Low Side Open - Cylinder 2.
I'm not sure exactly what this means or how to troubleshoot it without the special tools. All I have to work with is a volt/ohm meter. I did ring out the wires from the injector through the valve cover. They are good, how do I find which wires go from the 40 pin connector. The siloniod buzzes when the injector test is preformed. Could it be a mechnical problem rather then an electrical problem? Any tips will be appreciated.
Ken Gardner
Old Oct 3, 2008 | 10:23 PM
jhand124's Avatar
jhand124
Akghound:
I know nothing about the codes but here is what I found in a search....If you haven't tried that yet.
https://www.ford-trucks.com/article/...sel_Codes.html
Old Oct 3, 2008 | 10:34 PM
jhand124's Avatar
jhand124
Sorry, that doesn't really help. One of the enlightened ones will chime in soon.
Old Oct 6, 2008 | 08:41 AM
Action4478's Avatar
Action4478
NA11 DIAGNOSTIC TROUBLE CODES (DTCs) P1271-P1278
  • DTCs P1271-P1278 indicate a low side-to-high side open in the circuit between the IDM and the injector. The following table lists the circuits to inspect while performing these pinpoint tests, based on the DTC retrieved during the KOEO On-Demand or Injector Electrical Self Tests. Note: If all of the DTCs associated with an entire bank are retrieved, the high side circuit is most likely open.
    <TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TH vAlign=bottom align=middle>Cyl. </TH><TH vAlign=bottom align=middle>DTC </TH><TH vAlign=bottom align=middle>Low Side </TH><TH vAlign=bottom align=middle>High Side </TH><TH vAlign=bottom align=middle>Bank </TH></TR><TR><TD vAlign=top align=middle>1 </TD><TD vAlign=top align=middle>P1271 </TD><TD vAlign=top align=middle>555 (T) </TD><TD vAlign=top align=middle>1087 (O) </TD><TD vAlign=top align=middle>Right </TD></TR><TR><TD vAlign=top align=middle>2 </TD><TD vAlign=top align=middle>P1272 </TD><TD vAlign=top align=middle>556 (W) </TD><TD vAlign=top align=middle>878 (PK/Y) </TD><TD vAlign=top align=middle>Left </TD></TR><TR><TD vAlign=top align=middle>3 </TD><TD vAlign=top align=middle>P1273 </TD><TD vAlign=top align=middle>557 (BR/Y) </TD><TD vAlign=top align=middle>1087 (O) </TD><TD vAlign=top align=middle>Right </TD></TR><TR><TD vAlign=top align=middle>4 </TD><TD vAlign=top align=middle>P1274 </TD><TD vAlign=top align=middle>558 (BR/LB) </TD><TD vAlign=top align=middle>878 (PK/Y) </TD><TD vAlign=top align=middle>Left </TD></TR><TR><TD vAlign=top align=middle>5 </TD><TD vAlign=top align=middle>P1275 </TD><TD vAlign=top align=middle>559 (T/BK) </TD><TD vAlign=top align=middle>1087 (O) </TD><TD vAlign=top align=middle>Right </TD></TR><TR><TD vAlign=top align=middle>6 </TD><TD vAlign=top align=middle>P1276 </TD><TD vAlign=top align=middle>560 (LG/O) </TD><TD vAlign=top align=middle>878 (PK/Y) </TD><TD vAlign=top align=middle>Left </TD></TR><TR><TD vAlign=top align=middle>7 </TD><TD vAlign=top align=middle>P1277 </TD><TD vAlign=top align=middle>561 (T/R) </TD><TD vAlign=top align=middle>1087 (O) </TD><TD vAlign=top align=middle>Right </TD></TR><TR><TD vAlign=top align=middle>8 </TD><TD vAlign=top align=middle>P1278 </TD><TD vAlign=top align=middle>562 (LB) </TD><TD vAlign=top align=middle>878 (PK/Y) </TD><TD vAlign=top align=middle>Left </TD></TR></TBODY></TABLE>
Sounds like a loose OR burned wire
Old Oct 6, 2008 | 08:49 AM
Kwikkordead's Avatar
Kwikkordead
^^^^ What he said. ^^^^
Time to pull the valve covers.
