Sponsored by: Real Truck
Snowplow package??
Old Oct 3, 2008 | 08:35 PM
sonneborn3's Avatar
sonneborn3
Snowplow package??
I was considering putting a plow on my truck to make a few extra $ this winter, how do I know if I have the snowplow prep package? It is a 2004 SC/SB 350 FX4 6.0 PSD. It has dual alt's and a steering stabilizer, if that helps. If I don't have the package, do I just get new front springs?
Thanks
Old Oct 3, 2008 | 08:55 PM
ken kenmnedy's Avatar
ken kenmnedy
sounds like thats all your missing is the right springs for the plow(some psd trucks are advised in the manuel to not use a plow)they get nose heavy....but I know a guy that has 4 superdutys with the psd and 9ft boss vblads on em he has an extra spring put in the front but he also has a salt spreder in the back of them too...
Old Oct 3, 2008 | 10:43 PM
aldridgec's Avatar
aldridgec
Yeah, w/ the diesel it can exceed the max gawr for the front. Really, the spring code will tell you if you have the plow package from the factory or not.
Old Oct 4, 2008 | 12:28 AM
DaveAK's Avatar
DaveAK
Your spring code should read X. I have an 04 F250 and that's what mine reads.
Old Oct 4, 2008 | 07:07 AM
sonneborn3's Avatar
sonneborn3
Where do I find the spring code? Is it on the actual spring?
Old Oct 4, 2008 | 07:11 AM
350z's Avatar
350z
Look in the drivers door jam.
Old Oct 4, 2008 | 07:17 AM
350z's Avatar
350z
Smile
Also look at the tech folder in red , at the top of the opening superduty page , lots of good stuff their, if it has the plow package it should have a X under the "ax" part of the sticker and another letter for the rear axle code , Craig.
Old Oct 4, 2008 | 07:56 AM
sonneborn3's Avatar
sonneborn3
Thanks everyone!
Old Oct 4, 2008 | 09:29 AM
sonneborn3's Avatar
sonneborn3
My spring code is VY, what does that mean?
Old Oct 4, 2008 | 09:42 AM
PowerStrokeHD's Avatar
PowerStrokeHD
V is your front spring code which is 5200 lbs. If it had the plow package it would have X code 6000 lb. front springs...
Old Oct 4, 2008 | 10:03 AM
Tecman's Avatar
Tecman
I plow with the V code springs no problem. im looking for the heavier spring but only because I want a little more lift, the truck barely lowers with the plow up.
