Help
Old Oct 3, 2008 | 06:26 PM
Dizz0129's Avatar
Dizz0129
Help
i was goin to get on the turnpike when all of a sudden my clutch petal felt real strange..ii is very firm and wont disengage all the way when i push it to the floor..so im askin what could be the problem? when i push the clutch in the truck wont stop and its insanely hard to shift..about a year and a half ago i had a southbend put in it so it cant be the clutch..also it happened instantaniously like it was perfect right before that..i changed the slave cylinder and no luck still does it..any ideas?
Old Oct 3, 2008 | 08:02 PM
totin_tools's Avatar
totin_tools
Could the clutch fork be broken or something. Sounds like you may need to take the trans out and look. The slave cylinder is only at the top right, did you check the other end by the trans to see if it moves or is damaged somehow?
Old Oct 3, 2008 | 08:03 PM
F350-6's Avatar
F350-6
I assume the fluid level is good? Did you just replace the slave cylinder, or did you swap the master also? I didn't think it was a problem on the 02's, but you might pull the slave cylinder back out and check the clutch fork to see if it's bent. That might explain why the clutch won't disengage with the pedal to the floor.
