Quick easy HPOP fix anyone??
Old Oct 2, 2008 | 10:07 PM
dmueller71's Avatar
dmueller71
I have had this intermittent problem for a while, but now it's finally gatting bad. My HPOP resevoir keeps draining overnight. Luckily, I have a Fumoto drain valve, an empty glue bottle, and a crescent wrench in my engine compartment. Yes, I said crescent wrench, not a 3/16" allen wrench, cuz I've pulled the damn plug out to fill it so many times, I finally lost it. Luckily I happened to have a fine thread bolt laying around that fit, and I stole the O-ring from the plugs in my glove box that have been there for years after the SS crossover mod. So, after my long winded delemma, ids there an easy fix? tin foil and a penny? I'm gonna have to pull and rebuild my turbo soon, and I've gotten to the point where I can pull the HPOP in 45 min. or less, but that doesn't get me into the resevoir. What do I need to do OH WISE ONES?? I'm going to bed, but I'm hoping for the miracle cure when I wake up at 6. Thanks in advance for your opinions. Dan
Old Oct 3, 2008 | 07:00 AM
dmueller71's Avatar
dmueller71
Man, this is a first. 10 hours, and no replies. I can't be the only person that's had this problem
Old Oct 3, 2008 | 07:30 AM
bigsteve1969's Avatar
bigsteve1969
ill give you a bump im sure some folks will come by and give you what you need to know
F350-6's Avatar
F350-6
If you're looking for the check valve maybe this will help. Let us know if this works, and if you don't mind snap some photo's so we can see what this looks like without the aid of diagrams.
File Type: pdf
Old Oct 3, 2008 | 07:59 AM
Action4478's Avatar
Action4478
are you able to re fill by cranking the motor?
If not ,It may have to do with the LPOP..or the front cover ..
Most times ,from what I read ,,its Injector O rings ...
Old Oct 3, 2008 | 08:12 AM
Action4478's Avatar
Action4478
A little more info here :...
High Pressure Oil Pump
The high pressure pump has had the drain check valve deleted. This brings the variation of high pressure pumps used on the DIT to three. The pumps may be identified by the absence or presence of the anti-drain check valve.
  • On 1994 1/2 and 1995 model year engines up to serial number 187099, the initial high pressure pump did have a drain check valve but did not have an edge filter. The edge filter was part of the injection pressure regulator.
  • On 1995 model year engines starting with serial number 187100, up to serial number 201680, the high pressure pump did have a drain check valve and an integral edge filter. The edge filter was deleted from the injection pressure regulator.
  • On 1996 model year engines starting with serial number 201681, the high pressure pump does not have a drain check valve but continues to have an integral edge filter.
High Pressure Pump Gasket
  • The high pressure pump gasket has been modified to seal the standpipe between the pump and front cover.
Note: The correct gasket must be used to prevent internal and external oil leaks.
Old Oct 3, 2008 | 10:34 AM
Action4478's Avatar
Action4478
Heres a pic from amiller93
Name:  HPOP check valve.jpg
Old Oct 3, 2008 | 10:49 AM
F350-6's Avatar
F350-6
Isn't the check valve referred to here the one that used to be in the IPR which has now been replaced by the edge filter?
Thanks for sharing the pic from Alan. I've been meaning to find this on my truck, but always seem to forget about it when I've got the time.
Old Oct 3, 2008 | 11:17 AM
Action4478's Avatar
Action4478
more info here..
  • On 1994 1/2 and 1995 model year engines up to serial number 187099, the initial high pressure pump did have a drain check valve (only)but did not have an edge filter. The edge filter was part of the injection pressure regulator.
  • On 1995 model year engines starting with serial number 187100, up to serial number 201680, the high pressure pump did have a drain (check valve and an integral edge filter.) The edge filter was deleted from the injection pressure regulator.
    looks like the drain back check was moved to the block
Old Oct 3, 2008 | 04:57 PM
dmueller71's Avatar
dmueller71
OK, Action is totally confusing me. I have an 01 first off. If I crank the motor ALOT after 7 or 8 hours of sitting, it will pump full and start. Lately, if it sits more than 8 hours, i can crank and crank on and off for 20 minutes, and it won't fill. It's been sitting for 2 days now, so when I go out there, I know for sure that it will take a quart of oil to get it running again. I don't think it's a low pressure pump thing, because it drains overnight. And yes actually Action, I have hit it with a hammer, and it still don't work. Chris, thanks for the diagram. Alan actually sent that to me a few months ago, but I lost it. Plus, I can't see where that damn thing is. When I find it though, I will definately take some pics to share. Anyone else out there with the 411??
Old Oct 3, 2008 | 05:45 PM
PaysonPSD's Avatar
PaysonPSD
The gasket between the reservoir and the front cover may be leaking. It can leak down inside the front cover without any sign of external leak.
Old Oct 3, 2008 | 05:59 PM
F350-6's Avatar
F350-6
Rick (Action) has an older truck, so he spends a lot of time in the OBS forums. Don't ignore him though. He knows a lot about these motors. As for the valve in the diagram I sent you, Rick posted a picture of it above (from Alan), so that should tell you where to look.
Robin makes a good point about the gasket in the front cover, and Rick was right earlier about the common issues being injector o-rings etc., but that should give you signs of smoke at start up.
Old Oct 3, 2008 | 07:40 PM
Action4478's Avatar
Action4478
Two things can happen here ,,the pump itself is having trouble filling the empty 1 Qt res (it shouldn't have a problem & 40-50 psi oil pressure cold )& (or), the mating surface to the LPOP is worn & can cause a leak..(Happens very gradually)
Its the upper O ring that leaks ,,usually when the oil is hot ,,leaks back into the motor ,,It shouldn't (IIRC) cause excess smoke ,,,Long cranking can for sure ...(Can happen suddenly after a hard run)
You can pull the covers & look for oil bubbling up from the base if the injector (when hot)IPR DC% should be higher than normal also ..Not sure if it applies to all the motors old & newer,, OBS has a de airiation valve that can come loose ( rarely)....Pic here ...
Old Oct 3, 2008 | 07:45 PM
F350-6's Avatar
F350-6
Any idea why this would be eliminated? Sounds like a good idea on paper.
Old Oct 3, 2008 | 08:02 PM
Action4478's Avatar
Action4478
If it comes all the way loose ,causes a no start ,,I 've only heard of it once ...Its captive & won't fall out(completely) until you remove the cover ...
