Help With Intermittent Vibration Please
Old Oct 3, 2008 | 05:07 PM
MiracleMax's Avatar
MiracleMax
It sounds like what happens when you run over rumble strips, or the grooves on the berm of the freeway. Lasts for 1-2 seconds. It might do this 2-3 times a minute, or go for 5 minutes without doing it. Any speed above 30 mph. Four new tires, and air is up to snuff. Definitely not balance either. Trans? Anyone ever experience something similar? Appreciate any help. 94 F150 std. cab 2wd 302 auto.
Old Oct 5, 2008 | 02:12 AM
customfoam's Avatar
customfoam
check your tierods
Old Oct 7, 2008 | 02:50 PM
rattosh51's Avatar
rattosh51
Could be u-joints on the driveshaft...or a number of things.
Old Oct 10, 2008 | 04:14 AM
Opossum's Avatar
Opossum
Take a good look at your driveline pay special attention too the support bearing, shake things around somthing is loose or bent, maybe from the tire shops lift.
Old Oct 10, 2008 | 06:01 AM
dan91ford150's Avatar
dan91ford150
Sounds like torque convertor lockup shudder to me...
