'chatter' noise
Old Oct 3, 2008 | 04:22 PM
mike l c's Avatar
mike l c
Exclamation 'chatter' noise
my trans makes 'chatter noise any one got any info
Old Oct 3, 2008 | 04:28 PM
liftedgrocerygetter's Avatar
liftedgrocerygetter
It would help if you have us some info on your truck and when you are hearing this "chatter", how fast your a going, ect.
Old Oct 3, 2008 | 05:41 PM
camodown's Avatar
camodown
First off, Welcome!
My truck had a chatter if i forced it into t/c lock mode at idle in park or N. It otherwise has gotten quiet. There are 4 things i can think of.
1) Torque converter bolts loose
2) Internal torque converter damage
3) 2001 trans with noisey converter ("Normal" just noisy)
4) Flywheel cracked
Pull the inspection plate and check it out. Does it chatter under load, at idle?
Old Oct 4, 2008 | 01:36 AM
4inchlovin's Avatar
4inchlovin
if it is a stick **** a chatter noise is very common and not a problem
Old Oct 4, 2008 | 02:00 PM
camodown's Avatar
camodown
good point. If it is a manual, they are known to have gear rollover noises at low speeds in 1 and 2 with the 6 spd. The ZF-5 (5 spd manual) had gear rollover in 1st. The ZF5 I had bad gear rollover in 1st but still runs with over 240,000 on it...
Old Oct 4, 2008 | 02:52 PM
4inchlovin's Avatar
4inchlovin
LOL I guess i forgot to put the F in SHIFT so they blocked the word!!! LOL Sorry! It was not on purpose!
