which intake for a hot rod cruiser
At $50/ ft lb and $300 cost for an RPM intake, sounds like bear is suggesting there is only a 6 ft lb difference in the torque curves between an "S" intake and an RPM. That means 40 years of engine development and research has resulted in a SIX measly foot pound increase in torque. Hardly.
There was an SAE paper done in the 60's that suggested right angle bends in the intake flow would help fuel air mixing and engine performance. They were wrong on both counts. Ford intake manifold testing for the GT 40 program and others showed the log style intake design was flawed. See the Ford GT 40 SAE papers. Look at ANY new engine... theres no log style intakes anymore anyplace.
Mopar Muscle Magazine recently did an intake manifold comparison test using 12 different intakes on a big block mopar. I quote: "Just to see what would happen, we bolted an original '67 440 HP intake manifold to our testbed. The flow numbers were pathetic". The RPM intake showed a 32 cfm increase at 0.500 valve lift over the 67 HP intake.
Barry R is correct, and I stand behind what I said earlier. The RPM intake makes a great torque increase from off idle to max RPM-right where street driving uses it.
The "S" manifold if you are gonna stay with the stock small port heads. Otherwise if you are going with Medium Riser heads, like the CJ heads, then think about the Edelbrock or the BT or even and old PI manifold and a lot more cam too. For a street hod rod, lots of lift but keep the duration reasonable or you just kill the bottom end. In a street motor, bottom end and mid range are everything.
Something to keep in mind.....HP is a function of torque.
HP=TQxRPM/5250
TQ=HPx5250/RPM
Think of it this way....Hp is the RATE at which torque is made. The more hp you have the more quickly tq is available.
500lbft x 2000/5250=190.47hp
500lbft x 2500/5250=238.09hp
500lbft x 3000/5250=285.71hp
If you can maintain a flat, broad tq curve, the hp will climb. if you could build a motor to make low rpm hp, you'd probably never get the car/truck to hookup on the street.
300hp x 5250/2000rpm=787.5lbft
300hp x 5250/3000rpm=525lbft
It really isn't one or the other that will get you vehicle moving, as hp and tq are almost one in the same. They are just different ways of expressing the way energy is used to do work.
HP=TQxRPM/5250
TQ=HPx5250/RPM
There is no reason to believe that a manifold that makes more horsepower will not deliver more torque as well. As long as they are rationally comparable (no dual plane versus tunnel ram stuff) a good intake can outperform a weak one at every single point on the RPM curve from idle to window.
The idea that you need to give up on horsepower to get low end torque is simply not true. The Engine Masters test have bourne this out very clearly. I have run both huge single plane and modest dual plane combinations. After a huge amount of testing I can say the differences are there, but nowhere near as dramatic as you may think. The current one had an insanely huge Dove single plane and still made 500 lbs/ft at 2500RPM - 427 cubes and 10.5:1.
HP=TQxRPM/5250
TQ=HPx5250/RPM
HP=TQxRPM/5250
TQ=HPx5250/RPM
I'm talking torque which shows up as real street preformance improvement and you are talking horsepower, which for the street race is next to useless. When will you guys understand that horsepower is a top speed indicator, and just how much time do you run a street rig at top speed, want to try next to never. Torques is what makes acceleration and that is the number you want to increase and keep peak torque around 3000 RPM max and a big flat torque curve starting at around 1500 to 1800 and extending to 3500 to 4000 RPM Horsepower is for racers and torque is for the street machine. Yet all you know it alls talk is horsepower.
The last thing I said was Torque, and the articles I referred to, if you bother to read, mention torque increases thru out the rpm range. My recommendation of the rpm intake is based on personal experience, and numerous articles. your attitude sound like a bunch of opinion, and the rest of us are all ignorant, but your next to God!! Theres been plenty of other posts on this forum where folks are not impressed with your mr perfect style. YOu chose to assume we all talk HP. You have good comments some of the time, otherwise your attitude just pulls this forum down.
What other factory aluminum manifolds resemble the cast iron 428 CJ other than the PI? In a comparison between a PI, an Edelbrock F427 and a Sidewinder, which one would be the most beneficial for the street? They're all dual plane with large runners. Which would most likely have been found in a scrap yard?
Without dyno numbers or time slips on the track your feel is even less than opinion. My opinion is backed up by the numbers seen on the dyno in the shop I worked at and on the track while racing. Seat of the pants feel tells you nothing and magazines sell advertizing and aim to make those advertizers happy. So who's ignorant now?
I doubt that you will find any of the above in a scrap yard.
Buy the Edelbrock and enjoy your engine. In a years time, $340 is less than a dollar a day. Treat yourself and buy the good manifold. If you can find a sidewinder for less money, then get it. Both are great manifolds for your application.
Well the deal is, is that a fellow Ford guy has a factory aluminum intake which he said is an aluminum version of he 428CJ, which I though was a PI. But he didn't say what it was. Anyways he said he'd sell it to me for $300. If it's a PI or a sidewinder I'll do it when I get the $$'s. If it is some early factory 4 barrel with smallish runners, I'll pass and opt for the RPM. So far by what I've read not only here but elsewhere, is that the PI, Sidewinder, Blue Thunder, and E-brock RPM are the best single 4v "street" intakes, with increases in both HP and torque across the board.
Currently I have an Edelbrock Performer 390 for sale if anyones interested, good condition, $100.
#28
#29
intakes
Dust, the factory aluminum intakes are tough to find in a scrap yard. Most of them have been grabbed long ago. I wouldn't hesitate a bit to use an iron CJ intake on a truck. If your pal has an aluminum one that is not a P.I. or sidewinder or Edel F427, he might have a 427MR intake. These are single 4 barrel intakes that look a lot like the P.I., and could be mistaken for one if you don't know the casting number. They're a very nice intake. There are also some aluminum intakes that were installed on 352s and 390s, that were made before '67, that are very nice, but they have the larger, 'tall to the bottom' size ports. If you have the matching ports in your heads, you'll be fine.
If I were building Keisha's engine and were going to use the D2TE-AA heads that are already there, my first choice would be the Blue Thunder 427MR. It will match the D2s ports just fine, and being a dual plane will still have perfectly good low speed manners. My next choice would be a Ford 427MR intake, then a sidewinder, then an F427, then a P.I. My last choice in aluminum is the Edel RPM. All of the dual planes work very well, the reason the RPM is my last choice is because I just don't like the appearance of them....but all of the nicer dual planes are within 5% or so of each other. That shows you that Ford knew what they were doing when they made these things. If the Iron CJ intake is available, thats fine too. If Keisha is on a budget headers are most important now, and the stock iron S or T intake would be fine till more cash could be found. DinosaurFan
