79 2wd steering colum
Old Oct 2, 2008 | 10:05 PM
okiewelder's Avatar
okiewelder
Hello, I have a steering colum out of a 79 f250 2wd. I am wanting to use it in a another project that I am working on because I already have it and it has a colum shift. Anyway, there is a plastic bushing on the bottom of the colum and it is worn out and allowing slop in the shaft. Is there a replacement bearing or another plastic bushing I can buy?
Thanks, Steven
Old Oct 4, 2008 | 11:03 PM
fordtrucknut's Avatar
fordtrucknut
Bushing/Bearing
If they are still available from Ford. I'm unsure of the part number, but Numberdummy may know it. Being that it is from a 2 wheel drive, you will have to disassemble the colum to take the shaft out to replace it tho.
Old Oct 5, 2008 | 06:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by okiewelder
Hello, I have a steering colum out of a 79 f250 2wd. I am wanting to use it in a another project that I am working on because I already have it and it has a colum shift. Anyway, there is a plastic bushing on the bottom of the colum and it is worn out and allowing slop in the shaft. Is there a replacement bearing or another plastic bushing I can buy? Thanks, Steven
Need more info.
With or without tilt wheel?
With or without power steering?
Old Oct 5, 2008 | 10:54 AM
okiewelder's Avatar
okiewelder
Thanks for the replys, it is a non tilt and yes it did have power steering. I am wanting to put it in my 62 unibody that I installed a fatman mustang/pinto crossmember in. I think I can get the shaft components to bolt up. It is a nice clean colum that does not have the key with a colum shifter.
Old Oct 5, 2008 | 11:47 AM
NumberDummy
1978/79 2WD steering columns are not the same as 1973/77, 1968/72, or 1965/67.
I suggest you get a hold of Garbz2, who posts in the 1961/66 forum. He may be able to help you, because...
From what I've read here, these late 1970's columns have to be cut down in order to fit in 1961/64's.
D9TZ3C773B .. Steering Column Bushing-Lower / Obsolete
Reproduced by Dennis Carpenter: 704-786-8139
frty7ford
Apr 26, 2020 10:46 AM
fire521
Sep 27, 2010 12:38 PM
Farmall05
13
Mar 16, 2007 09:09 PM
Oddity
Jan 26, 2004 02:48 PM
jaroh
Nov 16, 2003 10:31 PM
