steering colum breakdown
Old Jul 18, 2007 | 11:01 AM
frty7ford's Avatar
frty7ford
does anyone have a breakdown for the steering column my top bushing keeps backing it self off and i was trying to figure out why?
Old Jul 18, 2007 | 01:40 PM
daveengelson's Avatar
daveengelson
Here is breakdown from LMC catalog. There are other Ford truck suppliers who have simular schematics by running search on their catalog web site. If does not take you to the actual parts diag. then go to page 90.
http://www.lmctruck.com/icatalog/fb/0090.asp
If you should find part you are looking for, strongly suggest not ordering online but rather contact them and inquire if item is in stock, if not, go to the next supplier. Many of the Ford parts supplier's have small inventory and have to order the part from their source and it can take weeks even thought they may say they can get item in couple days.
Anyhow, hope info is what you are looking for. You may want to add the horn brush to your shopping list while you are at it, save on shipping cost and handy to have extra.
dave
Old Jul 20, 2007 | 01:24 AM
frty7ford's Avatar
frty7ford
thanks that is what I was looking for
Old Jul 22, 2007 | 12:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
[Please list the year and model and 2 or 4WD of the vehicle you are working on, I'm not a mind reader. Not all the steering columns are the same. 1961/64 is different than 1965/72. 1965/72 uses a similar setup to 1973/79, but the parts are different numbers. One (1975/77 sleeve) is a Ford only item, not supplied from the aftermarket world]
1965/66: What top bushing? No such thing. There is an upper and lower steering column bearing (LMC#19) and plastic sleeve (LMC#15). These parts are the same for 1961/72, and are still available from Ford and NAPA. These parts also are used on 1960's Falcons and Mustangs so they are easy to find. The LMC illustration does NOT show the bearing/sleeve at the bottom of the steering column, but they ARE there. Use white grease liberally on the bearings before installing them, do NOT install the bearings dry!
1965/66 F100/250 upper and lower are the same parts.
2-C3DZ-3517-A .. Upper or Lower Steering Column Bearing
2-B1AZ-3518-A .. Upper or Lower Plastic Sleeve
Old Feb 19, 2016 | 04:29 PM
UnknownCubicle's Avatar
UnknownCubicle
Sorry to bump an old thread, but I thought if folks were Googling the info, I'd go ahead and save them the time I spent looking for these parts.
LMC truck catalog page 56 has the parts and exploded view of the column for the 71 and 72.
LMC part number for the bearing is 45-0740
LMC part number for the sleeve is 45-0795
There is also a seal below the bottom bearing shown in the catalog, part number 45-0762.
Hope it helps the next guy who finds this thread!
Old Feb 19, 2016 | 06:12 PM
NumberDummy
Upper bushing is 3517, nylon sleeve is 3518.
Old Apr 26, 2020 | 08:19 AM
Strand10's Avatar
Strand10
Bill,
62 F100 3 SPD manual on the column.
Im having trouble finding the correct part number for this seal. It’s at the end of the shift linkage tube, inside the column.
Id also like to replace the column end cap where it meets the steering gear box.
Thanks in advance.
I’d also like to replace the column end cap
Old Apr 26, 2020 | 09:52 AM
TA455HO's Avatar
TA455HO
Lead Gopher
That's the bellows style boot. Here's some older info from Bill. He's actually already answered every possible question multiple times so all you have to do is read all of his older posts....lol.
https://www.ford-trucks.com/forums/1...eed-ideas.html
Not that this will help much - I see nobody seems to have any of that part number. Perhaps is it being reproduced?
Old Apr 26, 2020 | 10:46 AM
Strand10's Avatar
Strand10
Thanks TA
Another Q; what type of grease should I apply at the top of the column during reassembly and what type to apply via the fitting at the bottom of the column?
wedge542
Feb 19, 2021 12:37 PM
tseekins
2015 - 2020 F150
Feb 8, 2018 09:12 PM
Brian H
2009 - 2014 F150
Dec 15, 2016 07:37 PM
DevanTheDude
Apr 8, 2016 05:30 PM
444dieselrod
Mar 8, 2016 08:49 AM
