carburated small block with an e4od?
Old Oct 2, 2008 | 04:37 PM
coreyl302's Avatar
coreyl302
Lightbulb carburated small block with an e4od?
Can it be done?
If this setup doesnt work why not?
Old Oct 2, 2008 | 05:15 PM
andym's Avatar
andym
Yes, but you need a standalone transmission controller. Baumann engineering makes them.
Old Oct 3, 2008 | 07:39 AM
Conanski's Avatar
Conanski
Or you need to leave the stock computer in there with all the engine sensors hooked up to it so it can operate the trans normally, and add a TPS to the carb. There are NO performance gains to be had with a carb over EFI, and if the EFI system has a problem it will be easier and cheaper to fix it than replace it with old technology.
