Temp sensor- '91 4.9l
Old Sep 29, 2008 | 08:47 PM
Chevy 6.2D's Avatar
Chevy 6.2D
Ok, the temp gage on my '91 300 doesn't work. I eventually want to put a factory tach dash in it, but I wanted to test the sender to see if that was bad- I searched the forums for an hour- and looked at my truck for an hour. where the hell is the temp sensor? I found the one with 2 wires, but I'm looking for the one with one wire that runs the gage.
Old Sep 29, 2008 | 09:16 PM
quicklook2's Avatar
quicklook2
down on the side of the motor under the exhaust manifolds.
Old Sep 29, 2008 | 10:03 PM
Chevy 6.2D's Avatar
Chevy 6.2D
Thanks, i'll check it out tomorrow.
Old Sep 30, 2008 | 06:24 AM
ymeski56's Avatar
ymeski56
Der Postmeister
After replaceing the single wire temp sender, go locate a 87'-91' instrament display that includes the tach (& the tripometer if you want),at junk yard (E,F-series,Lariat or bronco) Buy it,unplug your, plug in the one w/ tach and the tach will begin working. w/o any wire adds or mods. Important note: Oil sender units are matched to gage so to increase the chance that the oil gage matches your sender from 33% to 100%, also take the sender. I switched out my tachless I.P. 87' F-150 w/ I.P. w/tach & tripometer from 91' lariat $35. total and 30 day warrenty exchange or refund is pretty standard.
Old Oct 3, 2008 | 08:08 AM
Chevy 6.2D's Avatar
Chevy 6.2D
I got to get me a tach dash one of these days. My truck has an aftermarket oil pressure gage, so if the factory one doesn't read right it's no big deal.
MackGuy
Nov 5, 2013 08:16 AM
thedaddycat
Aug 1, 2007 09:48 AM
2New2Fords
13
Nov 10, 2006 12:10 AM
mstinnett
1983 - 2012 Ranger & B-Series
Jan 4, 2006 01:42 PM
Earl
Sep 29, 2002 09:03 AM
