Back up lights
Old Oct 1, 2008 | 03:49 PM
RoyalFord's Avatar
RoyalFord
Back up lights
I pull a 14' trailer with my truck. I get home late at night sometimes and backing up my driveway is hard sometimes at night.
I would like to install backup lights underneath the rear of the truck. Anyone know of good lights to use? I want some that will last and that are pretty bright.
I would like to install them so you can't see them that much from the back of the truck... but enough that it will illuminate the driveway better.
Thanks
Old Oct 1, 2008 | 04:20 PM
BradyCouchman's Avatar
BradyCouchman
i have some construction equipment lights that i LOVE they are bright small and made of hard plastic....i would check out a tractor suply store or construction equipment store...i also would think they would be less $ then the "off road" one....
Old Oct 1, 2008 | 07:00 PM
bpounds's Avatar
bpounds
Check out this old thread. I would like to do this myself.
https://www.ford-trucks.com/forums/5...with-pics.html
Old Oct 1, 2008 | 07:34 PM
GregsSD's Avatar
GregsSD
I just picked up some rubber mounted utility lights at the International dealer while I was getting filters. They are cheap, durable, and put out decent light!
Old Oct 1, 2008 | 09:22 PM
MarkMoore's Avatar
MarkMoore
I bought some 55w loghts from AutoZone for like $10 to go on the back of my X. I kind of whish they were a bit brighter, but they work pretty well - these give a nice wide beam.
I guess I should really take a night time photo.
Old Oct 14, 2008 | 04:16 PM
tim.moman's Avatar
tim.moman
Pilot brand (found at Autozone) makes a backup light kit I have installed on a few vehicles. The light pattern is designed for this and works VERY well. I have used other types (fog) that do ok. Just not as wide on the pattern. The kit includes mounting brackets for easy atachment to the recieve hitch. They look similar to markmoore pic. The utility light style being covered on the back will look cleaner.
Old Oct 14, 2008 | 09:19 PM
jake00's Avatar
jake00
you might consider upgradering the lighting on your house, i've used backup lights before, but theyre nothing compared to a couple of 100watters mounted up high on the house, illuminating everything
Old Oct 14, 2008 | 10:29 PM
tim.moman's Avatar
tim.moman
Another thought would be backup lights on the trailer. If the truck is wired for RV plug you probably already have it wired in the harness.
Old Oct 15, 2008 | 07:10 AM
rebocardo's Avatar
rebocardo
You do not want them mounted on the truck, you want them mounted on the trailer rear or better near the rear bottom outside of the fender. Especially if you have to turn or are going down a hill.
On my last trailer with my lifted 4x4 van, I put lighted plow sticks on the rear trailer corners, that helped a lot.
Old Mar 31, 2013 | 08:36 PM
Mystic_Cobra's Avatar
Mystic_Cobra
I have a similar problem with my 40' GN trailer. I am planning to add some floods to the driveway but would also like some additional auxiliary backup lights on the trailer.
I was thinking they might do the most good mounted to the rear of my trailer fenders facing back and to the outside just a bit. Has anyone done this that can recommend a specific light? I'm thinking a flush-mounted white off-road LED light of some sort.
Old Apr 1, 2013 | 12:58 AM
Ford_Six's Avatar
Ford_Six
I've run into a similar issue with my big flatbed, it looks like the best place for lights would be under the deck just forward of the tires so I could see them in the mirrors. Maybe a set on the rear of the trailer as well, to fill in the void there, but put them on a switch in the cab so they can be used as loading lights as well.
Old Apr 1, 2013 | 09:53 AM
Mystic_Cobra
Originally Posted by Ford_Six
... but put them on a switch in the cab so they can be used as loading lights as well.
Easier said than done. If I want trailer BU lights that work via a switch do I have to do a bunch of custom wiring? I can't envision how that would work.
Old Apr 1, 2013 | 10:13 AM
tim.moman's Avatar
tim.moman
Dual purpose is not real hard. Just requires adding a diode on the backup light input so you do not energize the backup light when switching on manually. No need to control in the cab really. Once the trailer has backup lights is it just a matter of a switch and diode to tie to the aux power of the 7 plug. If installing from scratch and no RV plug on the truck - yes it will take some wiring.
Old Apr 1, 2013 | 10:52 AM
Mystic_Cobra
The truck and trailer are already wired. Both have 7-pin plug and the trailer already has backup lights. The trailer has interior 12V lighting on the ceiling as well as a breakaway battery. I'm just adding two more BU lights that will also be controlled by a switch in the trailer.
Old Apr 1, 2013 | 02:05 PM
tim.moman's Avatar
tim.moman
Pretty simply then. You need to install a diode in the reverse power wire then connect your switched aux power between the diode and the lights you are switching.
For safety of your brake system fuse the new circuit
Run power from you Aux power to your switch. Run a wire from the Switch to backup lights. If you stopped there the switch would try to energize all the lights on that circuit and the truck. To stop that you will place a diode in the reverse power wire to block voltage going up the wire. Put the band end of the diode toward the lights. Then connect your switched power between the Diode and the light.
simple diode example
The Diode
