Sponsored by: Auxito
Map/effie Hook up
Old Sep 30, 2008 | 10:36 PM
busybill's Avatar
busybill
Map/effie Hook up
Hi has anybody done a Map/o2 hook up for HHO on a 4.2 2000 F-150 4x4 need to no what wire on the map is for the signal to the ecu.Thanks
Old Oct 2, 2008 | 06:16 PM
chaser1602's Avatar
chaser1602
Ther is 3 wires on the maf.Power ground and signal.A test light or multi-meter will help you figure which is which
Old Oct 2, 2008 | 06:58 PM
busybill's Avatar
busybill
I'm sorry I thought I said map sensor and it has 5 wires any idea? which wire is the signal wire for the ecu?.
Old Oct 3, 2008 | 05:00 AM
chaser1602's Avatar
chaser1602
DOOH!!!! I am sorry.I didnt read it right.I got that from a haynes. I look later at the map.If youcan find a library with ALLDATA,or a shop that would look it up for you,that would be the best way to find it
What is HHO?
Old Oct 3, 2008 | 10:41 AM
projectSHO89's Avatar
projectSHO89
Originally Posted by chaser1602
What is HHO?
This stupid idea has been well covered in the Alternative Fuels forum....
