Used scangauge to pull the codes put in the code for camshaft crankshaft sync and it says it is not in sync just replaced ficm had a little black smoke
Couple things come to mind here
1. You must be Cranking/Starter Engauged while checking CMP/CKP Sync
2. There are several diffrent codes for Sync so you may have wrong Code. This is a Good gauge to have Setup on SGII when the truck runs so you can verify the Code is Correct
so did this CMP/CKP Sync Gauge work Before the troubles???or are you trying to program it now????
I can dig a few more SGII Codes up for sync if need be
Oh and it would be a Great Idea to start your own thread List problems and Year of truck and also any recent work along with any Trouble Codes you have gotten recently
Just make shure the numbers are taken exactly like this
Truck in PARK OR NEUTRAL all times during test
ECT at 190* or close to And EOT at 185* or higher
A/C OFF
#1-------KOEO=Key On Engine Off =record value
#2-------Low Idel (truck idel on its own)=record value
#3-------High Idel (2500RPM)=record value
