Horn Relay
Old Sep 30, 2008 | 05:42 PM
Cowboy34's Avatar
Cowboy34
Question Horn Relay
i have a 78 Ford F150 4x4 and i have looked all over under the hood and dash for the horn relay and still cannot find it.HELP
Old Sep 30, 2008 | 05:45 PM
Franklin2's Avatar
Franklin2
You may not have a horn relay if you do not have cruise. I am not sure about the 78's, but 80-up was wired this way.
Old Sep 30, 2008 | 06:35 PM
fmc400's Avatar
fmc400
MSEE
My 79 does not have cruise, and there is no horn relay either. A 78 would be the same, if you don't have cruise.
In general, a good way to find a horn relay is to disconnect the wiring at the horn, and then push the horn pad and find where the click is coming from. This is a moot point if you don't have cruise.
Old Oct 3, 2008 | 07:41 PM
Cowboy34's Avatar
Cowboy34
i dont have cruise,i bought a grant steering wheel and install kit and to be able to blow the horn i pulled one wire up under the horn pieces but i hope i can get it working the way it supposed to be
Old Oct 3, 2008 | 09:09 PM
Franklin2's Avatar
Franklin2
Usually the aftermarket wheels do ground the wire to blow the horn. In this case, you might have to get a bosch type foglamp relay and wire your own horn relay.
brcwelding
Sep 30, 2012 08:21 AM
smuglr
May 16, 2006 09:41 PM
Scott123
Feb 1, 2006 10:10 AM
donk
Feb 20, 2002 09:29 AM
lee
Oct 30, 2000 12:57 AM
