won't start hot
Old Sep 30, 2008 | 02:19 PM
kbaker2241's Avatar
kbaker2241
won't start hot
my 96 explorer v6 won't start after driving for a while. it will start within 5 min. after that it will crank and pop and sputter like it is flooded. it will try to run a little longer if i hold the throttle down when it fires but still pops and sputters with black smoke. let it sit for an hour and a half it will start just fine. i have tried 2 new iac valves and a different coil pack. not sure what else could cause it. any help?
Old Sep 30, 2008 | 02:36 PM
marragtop's Avatar
marragtop
Have you pulled the codes? There may be a code stored even if the CEL is out.
Old Sep 30, 2008 | 03:58 PM
kbaker2241's Avatar
kbaker2241
checked codes there are none
