code help
Old Sep 30, 2008 | 04:09 PM
  #31
bdrummonds's Avatar
bdrummonds
the reason you are seeing the puddle in the rear of the valley, is because the motor slopes rearward, and everything runs back there. check to make sure your fuel bowl lid is tight, and not cracked. the lieometer is useless, hand calculate mileage and then you will feel better.
If an injector was stuck open for that long you would have hydrolocked the motor by now.
Check and make sure fuel fill cap is not damaged, or cross threaded.
Old Sep 30, 2008 | 04:11 PM
  #32
Smokin''s Avatar
Smokin'
Smokin
I almost wonder if he has one of those "cap included" fuel filters so many of the members here have complained about
Old Sep 30, 2008 | 04:23 PM
  #33
vivojr21's Avatar
vivojr21
truck runs good just at idle a little miss but uther than that it run good
Old Sep 30, 2008 | 04:27 PM
  #34
vivojr21's Avatar
vivojr21
i don't have one of those cap included filters. i just finished washing the valley. i am going to run the truck and see if i could find the leak.
i am not going by the lieometer i am going by the miles and gallons i put
Old Oct 1, 2008 | 07:17 AM
  #35
vivojr21's Avatar
vivojr21
ok guys i have looked to see were the fuel in the valley is coming from but no luck i cant see it. is there some dye or something i can put in the fuel to see the leak
Old Nov 3, 2023 | 08:36 PM
  #36
ibrokeit's Avatar
ibrokeit
1st Gear
Passenger side fuel line
New to this and idk if you still need this but I would check the passenger side fuel line that runs under the turbo to the back of the head. It can rub on the turbo pedistal and wear a hole through the line. Good luck
Old Nov 3, 2023 | 11:46 PM
  #37
INFRNL's Avatar
INFRNL
Congrats to responding to a 15 yr old thread on your first post. It's funny, I see this all the time on other forums as well. I think It's a requirement.
Welcome to the forum though
Old Nov 4, 2023 | 03:37 AM
  #38
kenn_chan's Avatar
kenn_chan
Zombie Thread.
dudewayne
Nov 20, 2015 07:23 PM
buddy-z
1983 - 2012 Ranger & B-Series
Mar 10, 2012 12:42 PM
Joelong258
Jan 25, 2011 12:44 AM
cutlass
Sep 12, 2010 07:13 PM
KEVINS800
Apr 4, 2005 05:31 AM
