lame throttle response
Old Sep 29, 2008 | 10:32 PM
blownmoney's Avatar
blownmoney
Hello,new user/owner.Just purchased a 06 350 KR 55,000 mi 6.0,one reason I purchased is because about 3 yrs ago I rented one and drove from Vancouver Canada to Tampa FL to pick up a 25 ft grady white and the truck kicked butt the whole way (less than 6 days there and back 3600 mi each way,budget rent a truck was not amussed!) this thing would lay rubber with a tap on the throttle,finally got enough coin to buy one so I got this beautiful black 06 Kingranch and love the truck but......the truck could not spin its tires on a ice rink going down hill,you push down the throttle and you start going and after about 20 feet and some rpm and boost it comes alive and has tons of power.The truck has had the latest flash from the local ford morons who dont even Know their own products and some TSB's,pulled my EGR today and the thing is like new it runs great just seems to have a delay in inital excelleration,was thinking stuck turbo but you can hear the pitch of the whine vary at different rpms,maybe the gas pedel and engine arent talking to each other properly.Anybody got any ideas?
Old Sep 29, 2008 | 10:43 PM
donjamer's Avatar
donjamer
The accelerator pedal is fly by wire. meaaning there is a potentiometer that sends a signal to the computer to make the truck go..
My 06 had crappy response and they finally replace the acclerator pedal assembly due to rubbing and that made it better..
There is turbo lag but the bad accelerator amplified it..
See if you can get them to check that out..
Old Sep 30, 2008 | 01:27 PM
jfralph's Avatar
jfralph
I have had this same problem from day one. My truck sometimes seems like it won't get out of its own way, other times its scary. Dealership has no clue and tells me everything is within spec, and they won't do anything about it. I have taken a fellow employees truck, exact same truck as mine, to the dealership and offered to take them for a ride, they refuse. They know there is a problem, but refuse to do anything about it, they claim it is within tolerances. i.e. differences of being able to pull out into traffic or not, the difference between 12 and 22 mpg, just manufacturing tolerances. My thought is ford better tighten up there manufacturing tolerances.
Old Sep 30, 2008 | 02:00 PM
donjamer's Avatar
donjamer
What I would do is make a deal with them..
Tell them to replace the accerator pedal assembly.. If it doesn't fix the problem you will pay for it or some other portion.. If it does then you want a free oil change or 2 for them hassling you..
If they don't go for it then take it somewhere else..
Old Sep 30, 2008 | 03:28 PM
scottman70's Avatar
scottman70
I had my accelerator pedal assembly replaced and it made a noticeable throttle response difference on my 6.0!
Duallymade
Mar 24, 2014 08:16 PM
Harleyondown
6.2L V8
May 3, 2012 08:58 PM
Nipperdog
6.7L Power Stroke Diesel
17
Jul 15, 2010 12:34 PM
JamCracker
Jan 2, 2005 09:03 AM
