Will I avoid the KABOOM?
Old Sep 29, 2008 | 07:37 PM
canuckelhead's Avatar
canuckelhead
LOL!
I keep reading all your signatures and the gear you got and that's what causes the face you see in the pic below my name. ahahaha
The garage isn't heated and spring is a long way off after I get done with round one. Lots of thinking time, dangerous combo........
Old Sep 29, 2008 | 07:41 PM
CSIPSD's Avatar
CSIPSD
Originally Posted by F350-6
Welcome to FTE. Glad you decided to join in the conversation.
To help you feel better about it, remember the trucks with the 4100 were detuned by Ford to keep from killing the tranny. The stick shift was rated at 275 hp in 02.
There is no physical differance between the 6 speed and the auto as far as MAX hp goes thou...
Old Sep 29, 2008 | 07:59 PM
megawatt00's Avatar
megawatt00
Welcome to the Club. And I do agree with your statement above!!
Old Sep 29, 2008 | 08:11 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Just FYI, I have heard that the stock splits are capable of flowing enough to support up to 350 HP. This must be under ideal situations and I have not seen it done. I did make 311/640 with chip and some mild mods a few years back. Stock turbo and jectors they were.
Old Sep 29, 2008 | 08:20 PM
canuckelhead
"stock splits"? Are you talking the oil crossovers Mike?
Old Sep 29, 2008 | 08:22 PM
Tenn01PSD350
Split shot injectors my new friend, and welcome to FTE.
Old Sep 29, 2008 | 08:24 PM
canuckelhead
ahhhh,
possible next spring country, thanks
Old Sep 29, 2008 | 08:33 PM
hucka1a's Avatar
hucka1a
Welcome to FTE.
Old Sep 29, 2008 | 09:12 PM
canuckelhead
Thanks Huck!
Old Sep 29, 2008 | 09:31 PM
white Buffalo's Avatar
white Buffalo
Welcome to FTE Canuke!
For further thinking/moding down the road -
to help lower EGT's while towing on the bigger grades/mountains a bigger intercooler will help drop the EGT's. The 6.0 intercooler is better than the 7.3L stock one and can drop the EGT's 50 degrees or so, but the bigger more expensive DI Intercooler, Hypermax, & Spearco will drop it 200 degrees while towing. Also, a 1.15 housing for your stock turbo or a van turbo work very well for towing.
Best of luck & look foward to seeing ya on the road camping.......
Like said above, With the stock injectors & mods you have planned you should be around the 310 hp mark.
