Antifreeze leak
Old Oct 4, 2008 | 07:13 PM
SFeintuch's Avatar
SFeintuch
Thanks for the update, Glad to hear your all fixed up.
Old Oct 4, 2008 | 07:53 PM
cbradford's Avatar
cbradford
So it was leak dye for the AC and it should have been oily as the dye is in the oil, which means silver solder would have worked just fine and would be permanent fix as silver solder is used to solder in components on refrigeration systems.
Old Oct 16, 2008 | 10:36 PM
fordcountry's Avatar
fordcountry
Yes, the oily substance was the leak dye for the AC. I'm particular with my vehicles and I want them to run perfect so I decided to fix it right, here are some pics of the fix. The one single line was replace with 2 parts as I don't believe they can ship a metal freon line the length of an Excursion.
fficeffice" /><O></O>
<O></O>
<O></O>
Old Oct 17, 2008 | 09:11 AM
cbradford's Avatar
cbradford
Originally Posted by fordcountry
Yes, the oily substance was the leak dye for the AC. I'm particular with my vehicles and I want them to run perfect so I decided to fix it right, here are some pics of the fix. The one single line was replace with 2 parts as I don't believe they can ship a metal freon line the length of an Excursion. <o></o><o></o><o></o>
I too am very particular with my vehicles, and I service complex high tech refrigeration systems for a living, that's why I would think silver solder would have worked just fine.
russ_d_t
Aug 15, 2024 04:38 AM
kunder54
Apr 27, 2017 01:09 PM
shawnvhs2003
1997 - 2003 F150
Oct 28, 2013 10:31 AM
Mike Hannahs
Oct 10, 2013 08:29 PM
Dennis of KC
Nov 25, 2003 01:29 PM
