I looked under my truck and noticed a Antifreeze Leak I looked under the truck and noticed the antifreeze leaking around the crank shaft. I have never seen a leak from that area. I haven't pulled anything yet I was just wondering if anyone had something similar that could point me in a good direction before I start pulling parts off.
I looked up top didn't see any hoses leaking. looked all around the block. the only place I can see it coming from is behind the crank shaft pulley somewhere.
Try this link and see if you can get an answer, not quite as good as FTE but its still Ford. F150online Forums - Message Boards for 1997-2008 F150, Lightning, Supercrew, King Ranch, Blackwood, Mark LT Light Duty Pickup Trucks
In the meantime I'll look at mine and see if I can come up with something and get back later. A link should show up in your e-mail connecting you to my response if you have it checked in your "User CP" to accept responses. You might check further down the forum column and post your ? here "Cooling, Heating, Ventilation & A/C"
Looked at the engine (5.4) and I'd look at the water pump, that would be my guess since I had a similar situation on a 5.0. There is a drain hole in the bottom of the pump and when a seal goes you get e drip or worse and its directly above the crank.
Good Luck
