Clerance Lights ?
Old Sep 28, 2008 | 10:37 PM
bakerbuilttracks's Avatar
bakerbuilttracks
Clerance Lights ?
well when the ole 7.3 gets outta da shop i wanna put some clerance lights on it. the 08 ive been driving has em and ive grown fond of the look . i read the threads on it. as well as motomans install instructions but where can i get the harness and the lights. id rather not use the dealer keep costs cheep as possible. it their an online store that i can get the oem style lights and the harness from.. FEED ME
Old Sep 28, 2008 | 10:40 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Ford Parts and Ford Diesel Parts at Powerstroke Shop
Old Sep 28, 2008 | 10:50 PM
Stewart_H's Avatar
Stewart_H
I like these.
eBay Motors: FORD SUPERDUTY F250 F350 LED CAB ROOF CLEARANCE LIGHTS (item 130256054576 end time Oct-17-08 11:37:13 PDT)
Stewart
Old Sep 28, 2008 | 10:52 PM
bakerbuilttracks
thanks guys appericate it
Old Sep 28, 2008 | 11:00 PM
Lovin7.3's Avatar
Lovin7.3
I got mine threw JC Whitney. They are factory lights. I think they were 38 bucks pluss shipping.
Old Sep 29, 2008 | 07:23 AM
dsquared's Avatar
dsquared
I pulled this from the Excursion forum:
eBay Motors: FORD F250 F350 SUPERDUTY CAB CLEARANCE LIGHTS LOOK!!!!! (item 300261400359 end time Oct-01-08 10:30:33 PDT)
Now you heve lots (too many?) choices!!
Old Sep 29, 2008 | 07:58 AM
03_PSD's Avatar
03_PSD
Those are the ones i got still waiting to go on
Old Sep 29, 2008 | 11:18 AM
DieselBeast01's Avatar
DieselBeast01
does anyone know where to get a template though. I want to buy some, but I also want to make sure that I have a template to go by. I don't want to be drilling holes in the roof if im not sure that they are in the right place.
Old Sep 29, 2008 | 11:32 AM
Stewart_H's Avatar
Stewart_H
Here ya go, from the site most everyone uses, Motoman's site:
Motoman's Madness
"Next came the very important part... measuring! Just trying to find center on the weird shaped roof was a challenge. Once the center was determined we used the following measurements:
  • All lights 5.5" from windshield rubber to center of plug hole of light. (7/8" hole)
  • The lights on either side of center are 8" to hole center
  • The next lights out are 13" to hole centers.
| ----- 13"----- --8"-- --8"-- ----- 13" -----
Vince made a template out of nylon so we could set the holes in the proper location. We used a center punch to indent for drilling. The tape was used to reduce the flaking of the paint during the drilling process."
Hope that helps.
Stewart
Old Sep 29, 2008 | 10:19 PM
bakerbuilttracks
thanks guys yea a templet would be nice but having a good ole carpender for a dad and some skills of my own haha i think im just gnuua use moto mans tips. but where do u get the harness and where dose it plugg in
Old Sep 29, 2008 | 10:43 PM
bdrummonds's Avatar
bdrummonds
Motoman's Madness
Hope that helps.
Stewart
Finding the center is easy, take a 4 foot carpenters level, lay it up and down on the windsheild, and line up the mirror mount with the center point in the wiper valance. take a measurement form both sides of the windshaild to the level and adjust till they are the same.
worked for me, pics in gallery.
the harness plugs in down behind the pax lower kickpanel, in fron of the door
I went with the JC whitney lights, and made my own harness. 2 wires, 1 red, 1 black, some blade connectors, and two scotch lock connectors to the running light wires. I also used self tapping metal srews to secure my lights to the roof. I only had to drill 5, 1/2 inch holes. 2 hour job, (about a six pack) now that I've done it once.
Old Sep 29, 2008 | 10:54 PM
bakerbuilttracks
i just looked on jc whitney and couldent find em am i an idiot or what i do want the oem look though orange and just like factory ones. and bout that kick pannel and pluggin em in pass side kick? what to look for? where to splice into or do i need a plug? and.... if i want the harness where do i find one..
Old Sep 29, 2008 | 11:16 PM
bdrummonds's Avatar
bdrummonds
Look Here http://www.jcwhitney.com/autoparts/I...D:100000202462
the little pic on the left shows what the Super Duty lights look like. Look at my thread about my truck getting a bath today and you can see them installed.
the running light wires are brown(+) and black(-), they are located in front of the pax door behind the plastic kick panel. tap into the brown wire and run about an 8 foot length of red wire, and then do the same with a black wire tapped into a ground. reomve your A pillar cap, and your visors,and your mirror, remove the large pushpins that hold the headliner in and drop it down some. snke the wires from the kick panel up through the A piller and then lay them in the headliner. Measure drill and mount your lights, and then just tap the red to red, and the black to black, test, replace all disassembled parts, and your done. the hardest part of this job is just getting started. JUST DO IT.
Old Sep 29, 2008 | 11:59 PM
twags6's Avatar
twags6
Motoman's Madness
Hope that helps.
Stewart
Thats the site I followed. The lights turned out great. I picked up all my parts from the local ford dealer. Take your time and triple check your measurements!!!! I goofed a few times. Lay the lights on the marks you're gonna drill and stand about 20ft back to make sure it looks good.
Here's a shot of the connector you hook into in the kickpanel.
Old Sep 30, 2008 | 12:13 AM
my79f's Avatar
my79f
brandon, have you had any issues with water getting in through the self tappers, and what size did you use?
