Need help QUCIK STRANDED.
Old Sep 28, 2008 | 05:00 PM
Chassisman's Avatar
Chassisman
My Dad is using my 99 Dually towing my 40ft enclosed trailer...he's cruising about 65 and he said when the turn on the headlight switch to flash a trucker he was clear the truck acts like its shutting down....ANY IDEAS??...HELP !!!!
Old Sep 28, 2008 | 05:01 PM
Chassisman's Avatar
Chassisman
He said it acts likes it losing power....not electrical power just bogs down badly.
Old Sep 28, 2008 | 05:03 PM
ron's power stroke's Avatar
ron's power stroke
weak battery or alt.maybe..does it run ok with lights out?? these trucks need all the juice they can get to run right..
Old Sep 28, 2008 | 05:04 PM
white Buffalo's Avatar
white Buffalo
IF the healights initiated the problem I would suspect the alternator or batteries. These engines have quite a bit of electronics and need at least 10.5 V to fire the IDM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Where is he? Someone else will be here quickly.
white Buffalo
hey Ron, you type fast!!!
Old Sep 28, 2008 | 05:05 PM
Chassisman's Avatar
Chassisman
he said it runs fine with them off.....he says the volt meter doesnt change....thanks for the quick reply
Old Sep 28, 2008 | 05:06 PM
Chassisman's Avatar
Chassisman
he's on his way back from the NHRA Div 7 finals in Fallon Nv headed to Calif...he'll be in Reno soon...
ron's power stroke
just sat down and it was the first post i see...
you cant trust the stock gauge..if it runs ok with lights out..id say batteries or alt giving up
Old Sep 28, 2008 | 05:10 PM
Chassisman's Avatar
Chassisman
I was kinda leaning that way....Im going to have him unplug the trailer to see if the battery in the trailer went bad and is pulling it down....I made the mistake of putting a 50 amp fuse instead of a 30 in the dist. block before he left.
Old Sep 28, 2008 | 05:11 PM
white Buffalo
One bad battery can drag the whole system down. If he sees a Walmart along the way they carry the batteries for our trucks and on Sunday probably is one of the few places open.
Old Sep 28, 2008 | 05:12 PM
white Buffalo
possibility, good idea.
Old Sep 28, 2008 | 05:17 PM
ron's power stroke
the battery on the trailer is just for the back up brakes right?? just un hook that from the truck..it should have pleny of juice to run them..that way dad still has lights...
Old Sep 28, 2008 | 05:22 PM
Chassisman's Avatar
Chassisman
The trailer battery is for the 4000lb Superwinch and Hydraulic landing gear.....he just called....wiring loom is melted from the trailer plug forward...GREAT !!!!!!!!!!!!.......I've never had any bad luck with vehicles...and in 2 weeks he's blown the tranny in his motorhome...broke the rear end in his race car....broke it again this weekend and has now melted my wiring harness...time for him to find his own stuff to mess up !
Old Sep 28, 2008 | 05:24 PM
ron's power stroke
that would do it...is it the harness on the truck or trailer???
