Explore 8.8 axle swap kits for "52 F1?
I installed a Explorer rear end in my 52. I cut the original perches off and the sway bar mounts that where welded onto the back of the tubes.I then used the sway bar mounts as the new spring perches. They look just like spring perches but are used for a sway bar. They fit the axle tube perfect and are narrower then the origianals perches, so they fit the narrower 52 spring better. For the shock mounts I took the mount plate that has the four holes in it for the U bolts and cut the shock mount off them and contoured them to fit the axle and welded into place.Took what was left of the plate and used it to bolt the diff. in. Looks great. There is a pic in my gallery but its not a close up shot.
86f150step
11-27-2015 06:30 PM
cdichiar
15
06-30-2014 10:53 PM
Reed
07-16-2013 12:14 PM
radramrod2
11-24-2004 12:24 AM
