wierd truck
DIESEL TURBO DIESEL
BUT the under hood pic clearly shows a early PSD but it has a brass radiator
with the cap on the top and top hose inlet on the pass. side like a idi rad. in fact it is a idi rad.
my 95 psd has a plastic top rad. with top hose on the driver side.
for sure the goverment didn't pay to swap to a psd, this takes time and EFFORT do you think some gov. mechanic would do this.
some body please explain was the 94 set up like this never had one
you can see it at www.govdeals.com under (trucks 1 ton and under) page 6
5th one down
another one just like it on page 5
As for the Turbo Diesel badge, every IDI Turbo and PSD 94 I've seen has had the same one.
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 1FT
Assembly Country: USA
Make: Ford
Body Style: Pickup
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: J
Brake System: HYDRAULIC
GVWR Class: Class H
GVWR Range: 9,001 - 10,000 Pounds
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: W35
Vehicle Line: F-350
Series: XL
Body Type: CREW
Vehicle Type: Truck/SUV
Engine Type - 8th Position
VIN Code: F
Engine: 7.3 L
Cylinders: 8
Fuel: Diesel
Model Year - 10th Position
VIN Code: R
Model Year: 1994
Assembly Plant - 11th Position
VIN Code: E
Assembly Plant: KENTUCKY TRUCK: JEFFERSON COUNTY, KY
Production Sequence Number - 12th - 17th
VIN Code: A37121
Prod Sequence Number A37121
Engine type F is Power Stroke
I have to wonder about the title restriction N
And I also have to wonder about the three speed manual tranny?
