What Engine Do I Have
Old Sep 27, 2008 | 10:04 AM
taneum's Avatar
taneum
I have a 1979 F-250 4x4 Ranger. I am wondering what engine I have in it. I thought it was a 400 c.i. but someone told me that Ford did not make the 400 that Dodge made that engine.
Michael
Old Sep 27, 2008 | 10:07 AM
projectbad78's Avatar
projectbad78
yes ford made it...not sure how to id it tho
Old Sep 27, 2008 | 10:14 AM
Rockstone's Avatar
Rockstone
If it's the original engine and a V8, then it is a 351M or the 400. I don't remember Dodge ever having a 400? GM had one.
Old Sep 27, 2008 | 10:18 AM
projectbad78
haha, thats funny
Old Sep 27, 2008 | 01:42 PM
LxMan1's Avatar
LxMan1
Dodge had one, it was a B engine using the shorter version of the Big Block like the 361 and 383 did. RB engines were the 413,426,440. It came in the 70's big cars.
I think just about all of the Big three mad a 400 at one time.
Old Sep 27, 2008 | 01:48 PM
Dr. Dirt's Avatar
Dr. Dirt
post the VIN number and we can decode it to see.
OR see if the sticker is still on the valve covers. EXAMPLE: mine says 4.9L (300). yours if orignal would say: 6.6L (400)
Old Sep 27, 2008 | 03:05 PM
Rockstone's Avatar
Rockstone
You learn something everyday, thanks.
Old Sep 27, 2008 | 03:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Michael
CACA del TORO!
Ford hasn't bought an engine from Dodge since 1912!
And..back then, the Dodge Brothers owned a large machine shop in Detroit, and made Model T engines for Ford under a contract.
When Henry bought out the Dodge's contract, the two brothers used the money to go into the car biz...in 1914.
After the Dodge Brothers died, the company was sold to Walter P. Chrysler in 1929.
1977/79 F100/350 4WD engine availability:
300 I-6 ~ VIN engine code B / 351M 2V ~ VIN engine code H / 400 2V ~ VIN engine code S.
The engine code is the 4th digit of the VIN.
EZ way to ID: The 351M's & 400's have 8 valve cover bolts per side.
Old Sep 29, 2008 | 08:50 AM
taneum's Avatar
taneum
The V.I.N. is F26SREG3124
Old Sep 29, 2008 | 08:58 AM
taneum's Avatar
taneum
Where do I find the front axle code, rear axle code, and the transmission code?
Old Sep 29, 2008 | 09:13 AM
bmuhlbach's Avatar
bmuhlbach
On the drivers door tag it list this info.
Old Sep 29, 2008 | 10:00 AM
taneum's Avatar
taneum
Someone told me the v.i.n. would identify the differential codes and transmission. The site I used did not do that. Can some decode my entire v.i.n. number or give me a site where I can do that. I used one that only decoded the manufacture plant location, the type of truck, and the engine size.
Old Sep 29, 2008 | 10:48 AM
Dr. Dirt's Avatar
Dr. Dirt
well here is probably what you used.
Your VIN number: F26SREG3124
Your Model Year is 1979.
Truck Series: F250 4 Wheel Drive
Engine: V8 - 400cid, 4BBL carb, 167-177 HP
Assembly on: San Jose, CA
I get you the other decoder later. I don't have it saved on this computer.
Old Sep 29, 2008 | 11:19 AM
NumberDummy
Someone told me the v.i.n. would identify the differential codes and transmission. Uh huh, yeah right! The site I used did not do that. Can some decode my entire v.i.n. number or give me a site where I can do that. I used one that only decoded the manufacture plant location, the type of truck, and the engine size.
Someone told you wrong.
You will not find the Axle or Trans code in any VIN, regardless of what year the vehicle is, or what type of vehicle it is.
1964/80 F Series trucks: The AXLE & TRANS codes are located on the Warranty Plate, located on the left door face below the latch.
Post the info here.
I have decoded over 600 VIN's and Warranty Plates on FTE. I use the parts catalog to decode VIN's and the codes off the Warranty Plate, not some decode book that's prolly wrong.
Dr. Dirt: There's no such thing as a 400 engine with a 4V carb. They're all 2V's.
Old Sep 29, 2008 | 11:32 AM
BrentNewland's Avatar
BrentNewland
How can you possibly keep track of that?
