Sponsored by: Real Truck
Mirror disassemble
Old Sep 27, 2008 | 06:15 AM
reddogracing's Avatar
reddogracing
Mirror disassemble
OK,here is what I want to do.I need ideas and advice.
I have power telescopic mirrors on my 01. I want to make them 3" narrower, but still telescope some. My idea is that if you could just get rid of the little extra, that 3" between the mirror and the base, the mirror would look better. And the truck would be 6" narrower.
So, how does the mirror lens come off, #1?
And once the lens is off, and the mirror off the truck, can the mirror be disassembled?
Thanks guys and gals.
Old Sep 28, 2008 | 01:04 PM
reddogracing
with all the mirror mods people have done, surely someone has some advice, here. Or the forum is just so busy I got bumped to bottom before anyone seen it.
Old Sep 28, 2008 | 08:30 PM
msgtg's Avatar
msgtg
Well...first let me say no...I haven't removed a mirror...but I do know it can be done because guys have swapped mirrors out before. Plus, I have a passenger side unit sitting in my workshop...as a spare.
Now as for taking it apart...you can take anything apart if you're careful and patient.
As for wanting to reduce the length of the two support tubes...good luck pal.
I guess if you're a really mechanically inclined you can do it....my gut call is that unless you can fuse plastic back together its gonna be a bear.
I do have to agree that it would look cool.
Joe
Old Sep 29, 2008 | 09:30 AM
RACERX7775's Avatar
RACERX7775
the telescopicarms arent plastic, they are aluminium.
Old Sep 29, 2008 | 01:02 PM
reddogracing
looking at it on the truck, i was thinking that i might be able to take a dremel to the pivot point, and shorten it on that end. Like racer said that part is aluminum and the rest plastic, so I would guess there is a screw somewhere holding the arm to the plastic base. The area closest to the door. i have to get it apart to really figure it out.
Old Sep 29, 2008 | 02:34 PM
Layson's Avatar
Layson
take it apart. I bet you can get it figured out...
this shows how they are taken apart...
http://www.kwmuth.com/techsupport/pdfs/21000220.pdf
Old Oct 4, 2008 | 06:27 PM
reddogracing
thanks that helps.
I dont have a prybar thatwill fit like they show, but i was told if you point mirror down and pull from the top it will come off. Just been afraid to try. I have week off, so maybe monday i will risk it. I will post pics once i start.
Old Oct 4, 2008 | 07:02 PM
miker67's Avatar
miker67
Good gosh, don't rip off the front, take off the back. The cover on the back of the mirror comes off with a little coaxing. Pry gently with a small screwdriver and look for the fastners. They are just little clips you have to push in. Do a search in this forum on painting the mirrors, and there should be instructions in one of them on how to remove that rear cover. The mirror assembly it self is bolted to the door with 3 ten or eleven MM nuts from the back side of the door frame. Open the door and look for some rubber gromets in the inside of the doorframe where the mirror mounts. You will have to pop of the little trim panel and they are underneath.
-edit- There is actually one model of the ford towing mirrors where you actually have to purchase that rear cover separately, or re-use your old one when you replace mirrors.
NotURMailman
Jun 18, 2024 08:46 AM
woodhead
Jul 22, 2016 08:46 PM
BigBlueOx
6.7L Power Stroke Diesel
42
Mar 30, 2015 02:07 AM
BLADE35
Dec 31, 2013 08:41 AM
bthr22
Dec 9, 2013 05:13 AM
