Offroad & 4x4
how much lift?
Old Jan 25, 2002 | 08:54 PM
caseyatthebat1's Avatar
caseyatthebat1
how much lift?
How can I tell how much lift I have on my truck? If I were to guess I would say about 6" of suspension lift but how can I be sure?
Old Jan 25, 2002 | 11:46 PM
orange peel's Avatar
orange peel
how much lift?
i have a 6" lift on my f-150 and am runnin 36's, if your runnin 35's or over its normally a 6" or higher, theres only one person that i know of who has 35's under 4" of lift and they fit and flex really good but its a k5 blazer and we call it the "mistery truck" cause no one knows whats happened to it.
Old Jan 26, 2002 | 06:17 PM
caseyatthebat1
how much lift?
I have 38's on it right now but I get a little bit of rubbing on a tight turn.
Old Jan 26, 2002 | 06:47 PM
orange peel
how much lift?
what year truck is it, because i dont think that they make an 8" lift for fords with the ttb front suspension.
Old Jan 26, 2002 | 07:03 PM
mic's Avatar
mic
how much lift?
SkyJacker makes a 8" lift for Fords with TTB front ends.
costly....
Old Jan 26, 2002 | 07:15 PM
mic's Avatar
mic
how much lift?
First find out what brand of lift you have, if not, look
at the front pivot axle bracket, and see what hole the TTB
is bolted in, the upper hole is 4" and the lower hole is 6".
so if you find that it is bolted in the 4" hole, and you want
to lift the truck to 6", then all you have to buy is new front
coil springs, and new blocks or springs for the rear depending
on how deep your pockets are. , hope this info helps..
Old Jan 26, 2002 | 08:06 PM
Ford79's Avatar
Ford79
how much lift?
rockcrawler_101
Nov 10, 2011 07:31 PM
blake2182
May 5, 2011 09:09 AM
fordinmudd
Nov 20, 2010 01:11 AM
cmcostan
Oct 27, 2010 12:31 PM
fordtruckman78
13
Mar 19, 2006 11:31 AM
