ok thats it i just did super chips tuner and had batterys unhooked while i put in gauges i also have a code that says exhaust back pressure sensor any ideals
just got done replacing mine you might want to check out guzzles EBP sensor and tube cleaning it wouuld probably help but in worst case senerio you have to buy a new sensor. most likley its just CLOGGED UP. if your tube happens to have rust holes (mine did) you have two options 1. buy a new one 2. make one out of brake line using old ferrils and threads
