Sponsored by: Auxito
Vibration Noise help
Old Sep 26, 2008 | 09:58 AM
Troncoso's Avatar
Troncoso
Hello:
Mi truck vibrates a lot when I put the gears on reverse and stops when I put it on drive, does any one knows how to fix this?, and also vibrates during idle but just a few seconds.
Old Sep 26, 2008 | 12:05 PM
bryans98's Avatar
bryans98
I think i'm currently having the same issue. Is it kind of a metallic, grinding vibration? I am not sure how to diagnose it on my truck but a friend said it may be my bearings...
Old Sep 26, 2008 | 12:56 PM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to the both of you, Bryans98 and Troncoso! I am not sure what the problem could be but a bearing problem is a likely guess. What model and year of trucks do you guys have? Information like what you see in my signature is always helpful when you are asking for advice. Good luck!
Old Sep 26, 2008 | 01:11 PM
Troncoso's Avatar
Troncoso
Thanks John
My truck is a F-150 4.2 2001, yeah a bearing could be but, I'm not sure because at idle it vabrates too not for a long period of time but i does
Old Sep 26, 2008 | 01:37 PM
Silver Streak's Avatar
Silver Streak
Motor or trans mount?
Old Sep 26, 2008 | 02:58 PM
bryans98's Avatar
bryans98
Mine is a 1998 F-150, 4.6L 4X2, with the long bed. Mine wont do it at idle but when i inch forward, say at a stop light or just a real slow roll, that's where i notice it most. left turns as well...
Old Sep 26, 2008 | 04:32 PM
KingRanchMan02
Bryans98 if yours does it only around corners, then you likely have worn out clutches in the rear differential. That is if your truck has a limited slip diferential. Take a look at the door tag and tell us what the code is for the axle.
Old Sep 27, 2008 | 12:01 PM
murph1's Avatar
murph1
with the truck off.....take a rubber mallet and tap around under the truck....amazing at the stuff that will resonate thru the vehicle...the vib could also be from tranny fluid needing to be changed...mine did it slightly before the tranny change....yes at a standstill
