question about boats
Old Sep 26, 2008 | 09:22 AM
freirefishing's Avatar
freirefishing
i havent used my boat in a couple of months now. i take it out the other night,dump it in the water etc...... i go and park the truck and my buddy is like your steering wheel isnt turning...
the steering wheel doesnt turn either way,not even a qtr inch. i cant move the engine from side to side either with my hands.
i noticed the rod that the engine slides across on doesnt have any lub on it what soever. must have come off in the rain and sun combined over the lst couple of months?
my question,if theres no lube on those rods,could it cause the whole steering wheel to seize? not move what so ever?
it has a nipple where i can put the hose on and pump in greese (which i did in the beginning this year)
or do i have some other issue that i dont know of (which isnt hard,believe me)
Old Sep 26, 2008 | 03:33 PM
tjc transport's Avatar
tjc transport
i ain't rite
the grease on the telaflex cable in the engine mount has hardened up and seized the cable.
you may be able to free it by pumping it full of grease.
otherwise, i cant tell you how to loosen it up. mine has been locked up for around 8 years now. i don't have the time to use the boat, so i never tried to free it up.
Old Sep 26, 2008 | 06:33 PM
freirefishing
thanks man ill check it out. i just went to west marine bought a gun and some lube
Old Sep 26, 2008 | 08:30 PM
Alcan's Avatar
Alcan
If you have a torch, put a rosebud on it and warm it up. That should melt the hardened lube enough to allow the new grease to flow through. Good luck man.
Old Sep 26, 2008 | 11:42 PM
quaddriver's Avatar
quaddriver
Im assuming outboard right? you are going to have to replace the steering cable or the gear housing under the dash, disconnect and make sure the steering shaft has in fact frozen.
Old Sep 27, 2008 | 12:34 AM
Bill W's Avatar
Bill W
Same thing was wrong with a project boat i bought 15 years ago... I just bought a new one ! You know how hard it is to find a push-pull stearing controll cable in AZ?
I found one in Florida though! works real good and nobuddy has one like it around here
Old Sep 27, 2008 | 05:11 AM
tjc transport
i ain't rite
buying the new one is not as big of a problem as getting the old one out though Bill.
Old Sep 27, 2008 | 02:24 PM
Bill W's Avatar
Bill W
Guess all i can say is, Good luck....
Old Sep 28, 2008 | 08:09 AM
GlennFordx4's Avatar
GlennFordx4
A buddy's boat did that all the time because he wasn't using marine grease to keep it lubed,you can try to get someone to turn the wheel while you turn the motor the same way and if it breaks loose grease it with marine grease do you have the teleflex greasing coupling for the cable if not I would get one.
thomasr
13
May 10, 2002 09:05 AM
BrianA
21
Mar 5, 2002 08:27 PM
