[FONT='Times New Roman','serif']Hello all,fficeffice" /><O></O>[/font]
[FONT='Times New Roman','serif']I need help from anyone who knows where the rear air module is located? I replaced the rear airbags and now the compressor will not run. I removed the compressor and it works ok on the bench. Fuse #4 -15 amp is ok. Power switch on. Any suggestions? <O></O>[/font]
[FONT='Times New Roman','serif']<O></O>[/font]
[FONT='Times New Roman','serif']Thanks<O></O>[/font]
97 EB expedition
Since the compressor stopped working after you replaced the airbags, I would look for a loose wire back there. Maybe one that goes to the leveling sensor?
Thank you for the ideas,
It was the relay, $150 later and working fine. What a pain to find I looked all over then found it under the lights. Air pump working for now with new filter & air spring from Arnott Inc.
