fuel leaking
Old Sep 25, 2008 | 11:35 PM
sparke454's Avatar
sparke454
fuel leaking
i have a fuel leak at the fitting below the fuel pump. does anyone know if there are any seals or gaskets in that fitting? also are there any performance modifications that can be done to that particular item.
Old Sep 25, 2008 | 11:56 PM
tjbeggs's Avatar
tjbeggs
Fitting below? Not sure what that means. There are two hoses (front of pump one below the other) and a banjo bolt fitting (1 1/4 hex on the bolt) at the rear of the pump. The banjo bolt has 2 aluminum gaskets that seal it up and the hose either could be leaking from loose clamps or junk hose.
