Sponsored by: Real Truck
strobes in mirrors?
Old Sep 25, 2008 | 10:28 PM
mbettez79's Avatar
mbettez79
strobes in mirrors?
I'm thinking about putting a strobe light in the side mirror light lenses. I haven't taken the mirror apart to see what's inside. Is there enough room inside the mirror and light lense to install a strobe light?
Thanks!
Old Sep 26, 2008 | 09:36 AM
riggz's Avatar
riggz
Which model? Pre 08 definately not as they are sealed LED housings. 08+ it might be possible, but I don't think there is enough depth. Plus you would have to lose either the running light or the turn signal to make it work.
Old Sep 26, 2008 | 10:11 AM
rwilimo's Avatar
rwilimo
I had this same idea but can't see anyway to do it, maybe a a surface mount led strobe?
Old Sep 26, 2008 | 10:35 AM
riggz's Avatar
riggz
I know a guy who installed some LEDs on his pre 08 towing mirrors. Was a PITA and took a lot of work to make it look right. The 08 style towing mirrors have more of a flat surface to mount something.
Old Sep 26, 2008 | 04:19 PM
mbettez79's Avatar
mbettez79
well darn, i thought that would be a great place to put some lights to get some side coverage. I have plenty of light front and back but from the side is very lacking. I guess I'll look for more options! Thanks for the replies!
Old Sep 26, 2008 | 05:48 PM
BenW84's Avatar
BenW84
No room in the 2004 TT mirrors.
Old Sep 26, 2008 | 06:40 PM
pbeering's Avatar
pbeering
About the only thing you can do is to install a Whelen TIR 3 or equivalent using the flush mount. There is not enough clearance to do much else. Sorry.
Old Sep 26, 2008 | 09:14 PM
tac53parsons's Avatar
tac53parsons
Whelen TIR 3 or LIN 3 is definetly the way to go. I think they run $50-$60 each. I have seven of them on my HD Road King.
Old Sep 27, 2008 | 12:03 AM
mbettez79's Avatar
mbettez79
thanks for the suggestions but I don't want anything that mounts to the outside of the mirror since I really suck at things like that. I can wire anything but mount a light on the outside to look good, forget it. It's too bad the led's are sealed light assemblies as that would be a perfect place for a strobe head.
Old Sep 27, 2008 | 08:15 AM
shorebird's Avatar
shorebird
Just a thought, but maybe you could get some sort of cab light, ( such as the Recon 264146BK ) and mount the strobe inside it. Then mount it on the back of the mirror? I wonder how it might fit. Pics of the Recon lights at https://www.ford-trucks.com/forums/7...k-warning.html
Old Sep 27, 2008 | 06:20 PM
riggz's Avatar
riggz
I don't think that would look good at all. Would be better off installing a linear LED in place.
Old Sep 29, 2008 | 05:48 PM
rwilimo's Avatar
rwilimo
Anyone have pics on the Whelen lights installed, I might consider it.
Old Sep 29, 2008 | 05:52 PM
riggz's Avatar
riggz
check out elightbars.org It's a forum dedicated to emergency lights/siren jocks such as myself.
Old Sep 29, 2008 | 11:10 PM
NorCalBusa's Avatar
NorCalBusa
They've been and are still down from Katrina damage.
Old Sep 30, 2008 | 05:04 AM
riggz's Avatar
riggz
You mean Ike. Yeah I forgot about that. I'll ask some of the regulars there what the status is.
