Bad LSD?
Old Sep 25, 2008 | 03:28 PM
rival904's Avatar
rival904
Bad LSD?
I have noticed, as per some of my other post on here, that there is a weird popping noise coming from something in my truck. Heres the conditions on where its happened
  • On grass, accelrating hard, the popping noise occurs. Not just a popping noise, can feel it also.
  • Taking a turn and accelrationg hard, will almost 100% cause the popping issue.
  • Also, the other day I was recovering a buddy who got stuck, and I had to go over some iffy terrian, well I flexed the rear axle to were my 33x12.50 on the back driver side was off the ground a little, and when I just barely hit the gas, it made a weird noise like something was free spinning inside the axle housing. Im wanting to point my finger at the LSD...
Is this a common issue with these trucks? Anything else to look at? Any help would be GREATLY appreciated.
Old Sep 25, 2008 | 04:08 PM
SteveVFX4's Avatar
SteveVFX4
yeah, you can feel the shuddering. The problem is the clutch packs in rear end. It was a common issue with the earlier models, there actually was a technical service bulletin (TSB) issued about this. I had my 04 fixed under warranty per the TSB.
Old Sep 25, 2008 | 04:14 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
test your LSD.
1 tire on pavement, the other tire on dirt (ie: side of highway). floor it
you should get some wheel spin. But if the LSD is working, your 1 tire fire will be minimized and the truck should accelerate fairly quickly.
a bad LSD will just let the tire on the dirt spin away without transferring power to the other tire.
as for the popping sound, try lubing your rear leafs. it's on a 04 F-150 right?...maybe a 05?
Old Sep 25, 2008 | 04:40 PM
rival904's Avatar
rival904
Yup, 2004. I will try and get a video tonight of the problem at hand. I am really concerned I will do more damage.
Old Sep 25, 2008 | 09:11 PM
1saxman's Avatar
1saxman
Spin out on some gravel - immediately stop the truck and go back and see if there are two scratch tracks. If so, your LS is working. The popping noise is usually taken care of with a diff oil change and additive from the dealer - make sure to use only LS oil in it. Did you buy it new? Just wondering if maybe somebody else put the wrong oil in it.
Old Sep 25, 2008 | 09:55 PM
SUPERDUTY_untouchabl's Avatar
My lsd works awesome but it will make noise's some times. Like the rare ocasion when one wheel spins it makes a horrible noise. Mine has never maid a popping noise though. Do what Tylus suggested and see what noises and actions occur when you do it.
Old Sep 26, 2008 | 12:04 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
some of the 04/05's have issues with noises out back...you might actually be hearing/feeling your driveshaft. do a search and look through the TSB's.
Old Sep 26, 2008 | 12:03 PM
rival904's Avatar
rival904
I saw the TSB for the slipyoke, could that be it? If so, is it something I can tackle in the driveway?
Old Sep 26, 2008 | 12:08 PM
Could be the drive shaft. I figured it was the lsd because it only does it when one wheel spins.
Old Sep 26, 2008 | 12:44 PM
SteveVFX4's Avatar
SteveVFX4
tsb 04-24-20 (i think this one calls for replacing the clutch packs)
FORD: 2002-2005 Crown Victoria, Grand Marquis, Mustang, Explorer, Mountaineer
2003-2005 Expedition
2004-2005 F-150
LINCOLN: 2002-2005 Town Car
2003-2005 Navigator
This article supersedes TSB 04-17-5 to update the model year and vehicle line coverage.
ISSUE:
Some 2003-2005 Expedition/Navigator, 2004-2005 F-150 vehicles equipped with a 9.75" or 8.8" limited slip rear axle, and 2002-2005 Explorer 4dr, Mountaineer, Crown Victoria, Grand Marquis, Town Car, and Mustang vehicles equipped with 8.8" limited slip rear axle, may exhibit a chatter, shudder, a binding sensation, or a vibration during low speed turns. On 4x4 vehicles, the sensation may appear to be originating from the front axle or the steering gear.
tsb 04-01-06
FORD: 1998-2004 F-150
ISSUE:
Some 1998-2004 F-150 4X4 vehicles with a one piece drive shaft may exhibit a clunking or grunting noise and/or a shudder sensation from the driveline. The condition will typically occur during light to moderate acceleration from a stop and/or braking. This may be caused by the slip yoke not sliding smoothly on the transfer case output shaft splines.
ACTION:
To service, lubricate the slip yoke with Teflon Grease (D2AZ-19590-A). Refer to the following Service Procedure.
Old Sep 26, 2008 | 02:35 PM
rival904's Avatar
rival904
2004-2005 F-150
2003-2005 Navigator
ISSUE:
tsb 04-01-06
ISSUE:
ACTION:
Thats deff it, it feels like its right under my feet almost.
Old Sep 26, 2008 | 03:28 PM
SteveVFX4's Avatar
SteveVFX4
too bad you're out of warranty though. How many miles on your truck? Maybe you can ask the dealer to cover it (or at least partially) since it is a known problem and has a TSB. I've heard of dealers giving a one time freebie repair if just outside of the warranty period.
Old Sep 26, 2008 | 03:43 PM
rival904's Avatar
rival904
Just recently hit 50k on the clock. I got a buddy who owns a shop and normally only charges me about $20 an hour for labor so Im not 2 worried...
Old Sep 28, 2008 | 10:21 PM
rival904's Avatar
rival904
does anyone know where I can get the clutch pack I need? Or is it dealer only? If so how much do they normally cost?
TheyCallMeBT
Apr 5, 2014 08:26 AM
Frdtrtnv8
2004 - 2008 F150
22
Nov 21, 2013 04:24 AM
tseekins
2009 - 2014 F150
64
Apr 22, 2012 07:29 AM
buck_
1978 - 1996 Big Bronco
17
Sep 13, 2010 06:44 PM
Voksboy
Nov 21, 2006 08:40 PM
