I am trying to replace my oil cooler. I have all the parts out and the motor mount bolt out. But I can not get the motor to tilt. Do you have any tricks or tips.
Depending on which bolt you took out, there is another one or two bolts.
Three bolts into the block.
Two bolts hold the upper and lower part of the motor mount together, one front and one rear of the cross member.
Two nuts hold the lower mount to the cross member.
A couple pieces of 2x4 under the oil pan on top of the jack after the bolts are out, and it should raise right up a couple inches.
Before you wrestle the oil cooler, put a block between the motor mount and the frame.
If the jack falls or gets knocked out, you do not want that engine falling on your hand.
Three bolts.... I was told one, and yes I RTFM . I took the one out behind the cross member. The other two seem like they could be a pain in the ***. But thank you for the heads up. From the way it looked in the manual, it looked like just one. That could be the reason I could not get it to move.
Thanks
I will have to wait to try it. The truck is outside and it is going to rain for the next few days. Hopefully Monday or Tuesday will be the day I can get this beast running after three years of sitting.
I had it running for about 2 minutes to make sure the cooler was leeking, but that was for testing only.
Well I pulled the two bolts out and still not able to get it to move. Now I found a fourth bolt in the area but not able to turn it. I have the cooler unbolted and ready to be pulled. i just need that extra few mills to pull it.
Does anybody have a pic so I can see that I am working on the correct bolts.
I broke down and asked for local help. He is going to pull and replace it for me. And yes I was and feel like I am still cover in oil/grease/and coolant but hey that the fun part....LOL
