I am replacing front end under the 66 F-250 with one from a 73 F-250 with disc brakes. The 66 had a elongated washer under the spring seat on the left side only. It appeared to be a shim between the spring seat and the radius arm. This part is pictured in some parts catalogs and not in others. What is this part? Why only one on the 66? Did they not use them on the 73? I have worked on Ford trucks forever and don't remember seeing this part before.
No pic shows up, BUT if it is what it sounds like, these were indeed shims which were used on an 'as needed' basis. My guess it has something to do with the front end alignment.
- cs65
btw, theres no pics at all in your galleries anymore...
Thanks Camper
I responded to your message but your box is full. We have frame repainted. I-beams, Radius arms and spindles installed. We have the rear springs with new bushings installed. We have Dana 60 painted, new brakes and seals. Hope to install this Saturday.
Thanks for your interest!
Pics can be seen at
www.Blackwaterforge.com
