Coil pack ?'s
Old Sep 26, 2008 | 01:48 PM
twisted84toyota's Avatar
twisted84toyota
it has a miss and I figure with over 100K on the odometer I'd be a few steps ahead by just changing out all of them.....................Thanks for all the info you all have been a great help!!
Off to napa to see what they got!!
John
Old Sep 26, 2008 | 01:57 PM
Heavy_Metal's Avatar
Heavy_Metal
Wow, thats like $450 you are "throwing away". It's only one bolt and a plug that holds the COP on the plug. Last time I had a COP go bad(intermittently without CEL) I performed my swapping of COPs and found it on the last swap. The whole process took me an hour and a half.
Old Sep 28, 2008 | 01:48 PM
sablejar's Avatar
sablejar
Have to agree, no point to replace them all.
Old Sep 29, 2008 | 08:32 PM
twisted84toyota
getting a "buddy" discount I have a friend thats the manager.............getting them at a good price.....$265/10 range
Old Sep 30, 2008 | 01:53 AM
1's Avatar
I still say just unplug em one at a time with teh engine running. Very noticable when you drop a cylinder from this. When it doesnt change the idle is when you found your bad coil. Your only unplugging for a couple seconds max so this hurts absoluyely nothing. Done this on a bunch of ford modulars and worked like a charm every time.
Old Jan 4, 2011 | 02:00 PM
JSPajak's Avatar
JSPajak
I have what I believe is an ignition miss but it happens only when it is raining outside. Could it be just a bad wire? Maybe I could find it by misting water at the coils and wires one at a time.
Old Jan 4, 2011 | 02:29 PM
jh818's Avatar
jh818
See if you have water build up near the PCM just below the windshield on the passenger side.
Old Jan 4, 2011 | 03:41 PM
6ofus's Avatar
6ofus
How do you know when a COP goes out or is going bad? What are the symptoms? Our Ex will run rough when we get to a red light. It just started this and it isn't that bad right now. It is just annoying. Could it be a COP trying to go out?
Old Jan 4, 2011 | 03:58 PM
wallz's Avatar
wallz
JS;
I would pull the coils and have a look also at the rubber boots that are under the coils. They are known to dry out and crack and not let the power get to the plug. While the boots are out you might want to use compressed air to blow out the plug holes.
Old Jan 4, 2011 | 04:00 PM
wallz's Avatar
wallz
Do you get a rough idle all the time? If so it could be your IAC.
Old Jan 4, 2011 | 07:55 PM
Turingmachine's Avatar
Turingmachine
CEL, PCM, IAC?
Sorry, just a new owner, trying get a heads up. Thanks.
Old Jan 4, 2011 | 07:58 PM
6ofus's Avatar
6ofus
No. It doesn't idle rough all the time. Seems like it has to warm up good. After we have traveled a ways, then come to a stop sign or red light, it may do it.
Old Jan 4, 2011 | 09:45 PM
  #28
Stewart_H's Avatar
Stewart_H
Originally Posted by Turingmachine
CEL, PCM, IAC?
CEL = Check Engine Light. Also known as SES light.
SES = Service Engine Soon light
PCM = Powertrain Control Module. The brain of the engine.
This is what gets overwritten when someone installs custom tunes via a handheld flash tuner, like a Predator or SCT Xcal 2, via the OBD II port. This is also where chips with custom tunes are installed, overriding the factory tuning.
IAC = Idle Air Control valve. Controls engine idle speed.
Stewart
Old Jan 4, 2011 | 10:04 PM
  #29
Turingmachine
Thank you very much, Stewart!
Old Jan 5, 2011 | 02:07 AM
  #30
Stewart_H's Avatar
Stewart_H
You're welcome, TM.
And welcome to FTE.
Stewart
PikeFire216
Modular V8 (4.6L, 5.4L)
44
Dec 22, 2016 07:09 PM
Hogtrapper
Mar 20, 2015 07:12 PM
miko6810
May 6, 2014 09:18 PM
mniewald
Jul 26, 2011 04:46 PM
71-4R3SONS
Modular V10 (6.8l)
Feb 22, 2008 12:32 PM
