Sponsored by: Real Truck
stuck in park!
Old Sep 23, 2008 | 06:38 PM
squigler's Avatar
squigler
stuck in park!
HI people i seems my f350 wont move unless its not running ive been chasing this thing for a while now and all my mechanics said its to spotty to find well now its broke and there all booked up till friday
Any ideas?
SQUIG
Old Sep 23, 2008 | 07:44 PM
riggz's Avatar
riggz
Can you elaborate a bit more? It won't move unless it's not running? I assume it's an auto transmission correct? Will it not come out of park when you press the brake?
Old Sep 23, 2008 | 08:21 PM
2002 F350V10's Avatar
2002 F350V10
I had a similar experience recently at work, and it was the vehicle will not shift from park when the brake lights do not work. That vehicle was not a ford though, but the problem ended up being a braking circuit fuse blew cause a tail light bulb filament broke and was touching the second filament in the bulb.
Old Sep 23, 2008 | 09:26 PM
squigler's Avatar
squigler
yup i was venting sorry!to take the truck from park to drive is a work out smetimes it would work somtimes not the mechanic said till it does it all the time he cant nail it down now its whe
Old Sep 24, 2008 | 12:25 AM
GregsSD's Avatar
GregsSD
It is most likely the brake switch down on the pedal (it is what keeps the shifter in park until you press the brake pedal).
To get it going temporarily you should be able to turn your key one click forward (without the truck started) and then move your shifter to neutral, then start the truck.
