Oil Leak - OR
Last spring when we come home I noticed a pretty messy oil leak. I have cleaned it up and found it is coming from the front of the 2" diameter connecting tube that goes between the the housing that holds the oil filter and the housing on the other end that bolts to the forward side of the block.
Does anyone know what this tube is called and if it has o rings or bushings that can be replaced?
Thanks, Vern
Our tech forums are loaded with experienced enthusiasts that can help you out. Here's two links to get you started: Super Duty And Heavy Duty - Ford Truck Enthusiasts Forums and 1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Checkout the boards and Good Luck!
