I got my truck back from the shop, leveling kit installed but on the way home I heard a grinding / sand papery sound coming from the front suspension. I got home (5 mile drive). I looked under the truck and found a torn drivers side CV boot. I called the shop while still laying on the ground. They are going to order the part today and replace it tomorrow. The shop owner took responsibility for the problem immediately.
You need to look at the brake dust covers on the back. I bent mine too putting it on. Just have to pull them out a little. They are just tin and will bend easy.
Well I got my truck back, it's perfect. Everything new, even the axle.
while I was there, I talked to them about my e-fan setup ( Lincoln Mark VIII fan and DC controller FK35 ) and there going to install it for free. If they like it there going to start advertising the setup.
