Need ball joint replacement info
Old Sep 22, 2008 | 10:59 PM
colesdad's Avatar
colesdad
I know it's been discussed here before. I need to replace the drivers side upper and lower ball joints and the axle U-joint while I'm at it. Can anyone direct me to the threads where this procedure is explained? My truck is a 1996 F-250 7.3 4X4 manual trans
much thanks
Old Sep 22, 2008 | 11:10 PM
strokin'_tatsch's Avatar
strokin'_tatsch
i would replace both the driver side and passenger side upper and lower ball joints while your doing it. can't find the threads yet..
Old Sep 22, 2008 | 11:18 PM
colesdad's Avatar
colesdad
did the pass side last sept . . . .
Old Sep 22, 2008 | 11:25 PM
strokin'_tatsch
ohhhh.. ok that's why i do them all at once. LoL. i'm going to check another site. i didn't find a thread on it here in any of the searches i ran.
Old Sep 22, 2008 | 11:37 PM
strokin'_tatsch
ok all i could find was a write up for ball joints on a 4x4 super duty. i don't know that there would be much difference between the two so i will post a link to it. this might give you an idea on how it's done, but the sizes of nuts and stuff may be different...
tiki wiki:TikiWiki : Ball Joint replacement
Old Sep 23, 2008 | 05:50 AM
Cuda_jim's Avatar
Cuda_jim
Here's a great write-up from racerguy right here on good ole FTE
It's for newer SD but most of it should be the same. ie. ABS & hubs ect.
https://www.ford-trucks.com/forums/3...ll-joints.html
Old Sep 23, 2008 | 07:22 PM
95psd's Avatar
95psd
Can the axle u joint be changed with out pulling the hub and stuff off? Looks to me like you should be able to.
Old Sep 24, 2008 | 06:53 AM
Cuda_jim's Avatar
Cuda_jim
Nope, the hub and stub need to come off for the axle shaft to be removed.
The axle needs to come out to replace the u-joints.
boosteddsm
Jun 15, 2011 09:44 PM
KRDiesel
Sep 12, 2009 02:22 AM
BMWM1
Jun 24, 2009 10:23 AM
jimwesselman
1997 - 2003 F150
Apr 16, 2008 02:56 PM
GreenBoonie
1983 - 2012 Ranger & B-Series
Apr 15, 2005 09:05 AM
