What would you do ?
It would be cheaper for you to be right and drain the oil anyways, then for you to be wrong and wind up with a locked up motor...
what like 30 bucks in oil tops compared to a possible 3k rebuild... Ill take the 30 bucks everyday...
Don't forget to drain the filter too, as it holds about 1 qt!!!!
Your engine isn't likely to instantly self destruct, but I sure wouldn't consider trying to run this lube 5K miles.
Just get it done soon, before you do any high speed, lugging, or tugging type driving.
Anyway good to hear your 4.0L has the correct viscosity lube in it & is now all fresh & clean inside!!!!
BTW did you remember to drain the oil filter too????!!!!
jd
Only at cold temps is their a meaningful difference in viscosity, with the 5W being less viscous than a 10W, or a straght 30wt.
The 5W will flow faster/easier on a cold start, where we're told most engine wear occurs, so the faster a lube will flow on a cold, high rev start, the better it is for our engines.
Ford has a TSB lube specification, listing engines that can use 5W-20 & those that are to use 5W-30. 02-1-9***ENGINE - ENGINE OIL - RECOMMENDED APPLICATIONS FOR SAE 5W-20 AND SAE 5W-30 MOTOR OILS - GASOLINE AND FLEXIBLE FUEL VEHICLES ONLY
The 4.0L engine is to use 5W-30, beause it's oil pump hasn't been upgraded to be able to provide the engines flow/volume needs, at hot operating temps, with a 20wt's lower viscosity. You can dig this oil pump info out of a Ford Q&A warranty policy manual to Dealers, but you'll have to scroll down about 5 times to find the oil pump part. Lots of other good
info there though, so it's worth reading through the whole document.
http://www.dantheoilman.com/fordoilfaq.doc
If we want to mess around with a lower viscosity crankase lube for our particular type of driving, we could incur the costs of regular UOA's & see how the wear metals & the oils viscosity, ect, is doing & get an idea if the change works for our engine, driving conditions & drive cycle, ect, but any vehicle warranty is out the window!!!!
For instance, going from a 5W-30, to a 5W-20 for mpg reasons, is good for only something like 0.5 mpg, so why the heck take the risk of using a unspecified viscosity lube, void our warranty, risk excessive engine wear, for 1/2 a mile per gallon increase in fuel economy?????
My 94 Taurus 3.8L originally was specified for 5W-30, but now is back specified by Ford to use 5W-20 if I want to use it.
For instance, I choose to run energy conserving Havoline 5W-30, which has a hot viscosity figure thats low on the 30wt scale, such that it's just about in the upper vscosity range of a thick 5W-20.
Some 5w-30 lubes have a hot viscosity figure that approaches a 40 weight lube & an ash number about 20-30% higher than one on the low end of the 5w-30 viscosity scale.
So if an engine consumes some oil between changes, that lube will produce more engine deposits & the engine will have more pumping losses trying to move the ticker lube around.
Using a better quality base oil, can enable a lube manufacturer to build an oil with a lower viscosity figure, use fewer aditives, have a lower ash number to limit engine deposits & still provide the needed protection.
So unless we want to spend some money on UOA's to see how a particular lube is holding up in a particular engine, for a particular driving style & driving cycle, just follow the OEM's lube sugestions, as it covers a worst case scenario & the maufacturer has already done all the wear tests for us!!!! lol
The manufacturer isn't going to specify any crankcase lube thats likely to increase his warranty repair exposure, because that 3/36 bumper to bumper warrantys cost, thats hidden in the prce of the new vehicle, that we just paid big bucks for, is gravy money for the manufacturer, so he doesn't want excessive warranty costs eating away at his bottom line gravy money!!!!
Now if he's managed to sucker us in for an extended warranty, he sure wants to protect that gravy money too, so now he has to think longer term about engine protection.
So protecting all that gravy money he's just extracted from us, calls for him being careful about what he specifies for us to use as an engine lube, because he now has to make sure what he specifies will cause that engine to last at least 8 years, with low probability of failure.
So knowing all that, we can save a bunch of bucks by betting with him, that if we use what he recommends as a crankcase lube, the engne will likely last at least 8 years with a very low probability of failure, if thats so, we don't need his extended warranty, or to incur a bunch of UOA costs trying to second guess him on what crankcase lube is best to use!!!!
A bunch more thoughts for pondering!!!!!
