P0455: Frustrated
Old Sep 22, 2008 | 08:41 PM
'01zr500's Avatar
'01zr500
P0455: Frustrated
OK.. I posted a couple of weeks back about an issue with a 2000 Exp. 4.0 SOHC and the infamous P0455 Code.
I replaced the fuel cap... No Luck.
I replaced the canister vent solenoid... No luck.
I gave up and took it to a shop for a smoke test. The mechanic said it was leaking at the vent solenoid that was replaced. He recommended checking the harnesses for a bad connection. I checked the wiring and all was good.
I took it back to the mechanic and he did another smoke test. Still leaking at the solenoid. He ran more diagnostics and said it was the body control module? (p/n xl2t-14b205-CD) Located under the dash by the radio. I replaced it. Drove the vehichle 60+ miles and code P0455 is back.
Any thoughts?
Could I have gotten a bad vent solenoid?
Old Sep 22, 2008 | 08:49 PM
aquanaut20's Avatar
aquanaut20
Originally Posted by '01zr500
OK.. Any thoughts?
Yes! When the tech was performing the diagnostics, did he not activate the vent.
Old Sep 23, 2008 | 07:11 AM
'01zr500's Avatar
'01zr500
Is there a way I could bench test the vent solenoid?
Ford'05HG
1983 - 2012 Ranger & B-Series
Oct 26, 2016 09:10 AM
rogerranger2122
Oct 3, 2016 09:09 AM
mkotalik
1997 - 2003 F150
Sep 26, 2016 11:42 AM
scarfacelocc
2015 - 2020 F150
May 14, 2016 05:05 PM
odgmatt
May 21, 2009 10:35 AM
