Replacing a window
Old Sep 22, 2008 | 04:40 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Exclamation Replacing a window
An article by Jared (Ford_Six)
Changing a Window 68-72 .: Articles
Old Jun 27, 2009 | 04:25 PM
piwalker's Avatar
piwalker
Question on windo removal
I read the article on removal of the 69 Ranger window. I have removed the window crank, arm rest and door panel. I have not removed the door handle. There are no access spaces etc. The inner door panel is solid. What did I miss? Is the black trim above the panel to be removed also? Thanks for any help....
Old Jun 27, 2009 | 05:51 PM
Ford_Six's Avatar
Ford_Six
You have to remove the door handle to remove the panel. Take another look at the article, especially the pictures- Pull off the perimeter trim on the panel (it just pops off), then take out the row of screws. With the handle taken off, that whole metal panel pulls right off, leaving a big hole to get to everything through.
Ford_Six
104
Jun 5, 2017 04:55 PM
jhicken
May 5, 2010 12:19 PM
BigF350
Dec 6, 2008 08:26 PM
tomtoc
May 21, 2007 10:37 PM
